New LS3 crate long block 19420382
Has anyone else received the new GM 19420382 LS3 430hp long block? I received mine today.
I pre ordered it at the end of November. I plan on dropping it into a 1955 BelAir 2dr hard top.
The production date is 11/19/20 and it looks like it was the 33rd one off of the line.
It has a 98-02 Camaro oil pan and all of the sensors. Ls3 heads and a harmonic balancer. No intake or exhaust manifolds, no coil packs, no flex plate, no water pump.
This seems like a great platform for a street rod engine. I plan on using FiTech Ultimate LS system on it using a factory Corvette intake manifold instead of the fabricated intake.
Hopefully the FiTech fuel rails and injectors will work on he Factory intake.
The following 4 users liked this post by Redchevyman:
Hell of a deal! Great find
I was thinking of grabbing one of these if they have any left once profit sharing rolls around. I was hoping no body would stumble upon these. Please delete thread. LOL
The following users liked this post:
lazerlemonta (01-12-2021)
then you have to purchase heads etc for a replacement motor its a hell of a deal. If your building a motor for a purpose, I agree with a built short block. If my motor went today in my c6 i would use this in a heartbeat <---- see what i did there lol
The following 2 users liked this post by lazerlemonta:
Che70velle (01-12-2021), LaBLKv6Z (01-12-2021)
DualQuadDave (01-13-2021)
The following 6 users liked this post by Mavn:
DualQuadDave (01-13-2021), FrankU (02-28-2021), G Atsma (01-13-2021), Kingc8r (01-14-2021), MixedE36 (01-14-2021), and 1 others liked this post.
The Terminator X is bad ***. This makes me wish I waited before buying my VVT harness and ECM w/ a reflash . Only thing I wish for on the Terminator X is dual oxy sensors . The learning function is great. Just re-cam your ride, change cam spec section in the software and start her up
Jimbo1367 (01-15-2021)
Time for a spring upgrade. LOL
LS3 Cylinder Head Assembly
P/N 12629063
- Aluminum performance head
- Fits any LS family engine with 4.000″ bore or larger
- 2.165″ hollow stem intake, and 1.590″ solid stem exhaust valves
- .550″ max valve lift
- As-cast L92 style intake ports
- D-shaped exhaust ports
- As-cast combustion chambers
LaBLKv6Z (01-16-2021)
