Turbo ls3 vs 427
Good afternoon everyone,
I'm planning a new engine for my 6 speed g body. I have two blocks I can use, either an ls3 block that I would do forged rods and pistons with a billet 7875 or a darton sleeved ls3 that is ready to be a 427. The car is mainly a street car, I do power tour and daily it in the summer. I'm looking to one day get back into auto cross. Car made 500 who with the current engine, but I'm looking for more power. Which would you build?
* If you're generally happy with your engine but wish it had some more umph and throttle snap, then the 427 is that engine. The change isn't going to blow you away though. It'll be more like, "Now that's the way I wish my last engine performed!"
* If you want a lot more power and trap speed, then the turbo hands down.
1) a 7875 is small for an LS3. You will have monster torque down low but it will run out of steam up top. It won't be as snappy as an NA 427 though. You can always upgrade turbos if you want more power. Just depends on where you want a powerband. Either way it'll destroy tires.
2) assuming you want north of 500whp, a turbo ls3 will have better street manners than an NA 427. Depends on if you care about drivability.
3) the ceiling on a turbo LS3 is much higher than an NA 427 and cheaper to boot.
Hmmm, what size turbo would you run then. I was told I could push the 7875 to around 1000hp before it ran out of breath?
Thank you
I think 1000hp on a single 7875 with that many cubes would be very difficult. Maybe small cubes on an import at a high pressure ratio or running twins would certainly do it. Is 1000hp your goal? For a single and 1000hp I'd probably look more at an 82mm or 88mm from VSR or a Borg Warner S475 series turbo.
No, not looking for 1000, that was just the figure in was given. Looking for around 700 hp on street trim and 800 on kill. Honestly, that's probably pushing it on a g body frame.
Thank you.
The complete setup will be an ls3 with texas speed cnc ported ls3 factory cast heads, approximately 10:1 compression with summit rods and pistons, Texas speed cam controlled by a holley terminator x max. Trans is a tremec magnum with a ford 9". The top end listed when on the l76 made 500whp/475 ft/lbs.
The following users liked this post:
ddnspider (01-15-2021)
I’d run the sleeved block regardless if it’s NA or turbo. Longer and stronger sleeves make it a no- brained. You just need to be realistic w yourself on ur goals.
G Atsma (01-16-2021)
I believe the OP stated he had these blocks all ready.
