HPR 468 peaking to low.
This statement is NOT factual as proven by your own words and our conversation & our texts after your 421" grenaded. You said a piston "kissed" a valve after you upped your shift point from 7000-7200 RPM.
Then you told me "Assembler" closed shop and left town before you could speak with him after the failure. You also told me you did not know or have record of PTV clearance and had also used 5/16" x .080 wall PR.
While it appears highly likely in this current situation a Ferrea valve failed in your 468" this did not occur in your 421".
Blaming Mamo Motorsports for a Ferrea valve failure is like blaming GM or Ford for a Takata airbag failure. In both cases one manufacturer trusted the reputation of another quality manufacturer's parts and Ferrea valves have an excellent reputation.
Unfortunately racing breaks parts obviously and you have broken a lot of parts to reach your goal of a 9-second truck and an iconic photo/avatar including engines, transmissions, and suspension/chassis components as well.
You have paid for many expensive lessons and to imply that the same valve failure occurred both times is disingenuous.
@BigDaddy97
@BigDaddy97
Default 447 stroker on the way!Well 2 weeks ago I had a catastrophic failure with my 421 (4.030 bore x 4.125 stroke) at the track. Over the winter I had a local shop swap the heads out for some Tony Mamo AFR Mongoose LS3 heads and a FTI powerglide. I've been shifting at 7000 and running upper 10.20's with no problems but decided to try 7200 and see if it would pickup, when a valve kissed a piston. The heads are destroyed, 1 piston is trashed, 1 bent rod, block is cracked, the cam is good. I spent so much over the winter that I'm now on a somewhat limited budget to get racing again. The shop that did the work won't respond to me at all.....grrrrr. So I decided to get the best/biggest shortblock I can afford,thus I ordered a 447 (4.155 bore x 4.125 stroke in a sleeved Gen iv block) from Texas Speed but then I will have to make due with what I have on hand for the rest of it, I have a set of CNC 821 heads from Katech Engineering, stock rockers with Straub bushings, 11/32 pushrods that are .120 wall, LS7 lifters, and I will reuse my hydraulic roller cam which is .623/.623 lift, 247/261 duration, 113 + 4 lobe sep, and also have a new LOD Speedworks intake that was ordered prior to the engine failure. Obviously I would like to get a nicer set of heads, and a LLSR setup but it's simply not in the budget at this time (maybe next year). My question to you guys is: I think I can break well into the 9's with this big engine that has a mild top end, what do you think? I would also like to thank Dan Miller (aka NAVYBLUE210) for his messages and phone calls of support and advice.....you're a great guy and it's much appreciated!
__________________
1997 S10, HPR 468 stroker, 13.5 to 1 compression, MMS 265 LS7 heads ,Carbon PST intake,105mm throttlebody, Custom Clydesdale ******* HR cam spec by owner,80 pound injectors,1 7/8 headers,FTI powerglide,FTI 8" 6000 stall,8.8 rear,4.10 gears.
@BigDaddy97
@BigDaddy97
__________________
i bounce mine off the limiter, 7600rpm , every time I drive it, over 30,000m
If you don’t want things to break , throw a stock engine in, but even then ,that’s not 100%certain.
When I looked at your pics, I thought the valve may have contacted the outer edge of the valve relief, I suppose that’s the head suppliers fault also
i think the saying goes “ you pay to play”
Sux you had this failure, hope all goes well when it’s back up n running
I have been running 650 lift stuff with the Ferrar valves but on cathedral stuff for several years buzzing them up to 7500 for hundreds of passes.I am swapping over to ls7 stuff so paying close attention to others failures and successes.
