Bay-to-bay breathing question
Old Dec 16, 2021 | 06:53 PM
Utinator's Avatar
Default Bay-to-bay breathing question
I saw this mentioned in another thread, but I didn't want to hi-jack that one. I was looking for clarification on what bay-to-bay breathing is and why it's important. Can someone explain this please? Is this only a concern with longer stroke crankshafts? Is it just a high rpm issue?
I heard that the truck engines don't have bay-to-bay breathing, but the car engines do. So, does that mean that the LS3 and L92 are not identical blocks? I know trucks and cars commonly use different intakes and cams, but I always thought the engine blocks were the same. Does anyone have a photo that shows the differences?
Old Dec 16, 2021 | 07:22 PM
01CamaroSSTx's Avatar
LS9
LS7
RHS
Old Dec 17, 2021 | 07:26 AM
Double06's Avatar
The bay-to-bay helps with Hi RPM breathing so on a truck less of an issue. Also the bay-to-bay does weaken the block a little so that is why they keep them on the trucks. The ls2, l3, ls7 and the ls9 all have the bay-to-bay breathing. The issue with the LS block because of its Y shaped and shallow oil pan design and 6 bolt mains the individual bays don't breath as well as the old school small/big block chevy. Basically, the non bay-to-bay blocks compartmentalizes the cylinder banks too much. The new Dart LS block does not have bay-to-bay but has the old 4 bolt main cap design and a wider bottom skirt. I think GM did tests and it was worth like 10-15 hp on the 505 hp ls7 motor. The bay-to-bay helps equalize the cylinders as it relates to the crankcase stuff. On blower motor guys are more interested in strength the crankcase breathing stuff that is why they use the 5.3 blocks. So the holes you see above are filled in on the 5.3 and truck blocks.
Old Dec 17, 2021 | 09:07 AM
Utinator's Avatar
Ok, thanks for the photos and explanation. I saw the "coves" cut out of the side of the block right where the cross bolts go into the main cap (pic below). I thought that was the breathing window. So, I need to look closer to the cylinder to tell if a block has a breathing window. Does anyone have a pic of an L92 block? They are more common than the LS3 or L99.
Old Dec 17, 2021 | 10:19 AM
grinder11's Avatar
You're correct, the "coves", or scallops, do aid in the bay to bay breathing. Earlier LS1 blocks didn't have the cast in windows in their blocks, but had a rather large hole machined thru the main caps. Some builders swear that the early blocks ('99-'00) are stronger due to not having the cast in windows. IIRC, all the Gen 3 blocks had the coves/scallops. If I'm wrong, I'll soon be corrected!!
Old Dec 17, 2021 | 12:44 PM
There might be some truth to that as I've seen three LS7 blocks that were used in high boost applications where some of the crank saddles had been torn from the sides of the block.
Old Dec 18, 2021 | 09:39 AM
grinder11's Avatar
I got my info from Steve@Race Engine Development. I value his experienced opinion.
Old Dec 20, 2021 | 02:56 PM
Utinator's Avatar
Is he the one that drills holes in the truck engines to make them bay-to-bay breathe better?
Old Dec 20, 2021 | 03:38 PM
Corona's Avatar
correct
Old Dec 20, 2021 | 03:44 PM
Corona's Avatar
would this be considered bay to bay with a Hole the entire length of the block? Iron block love..
Old Dec 20, 2021 | 05:31 PM
Yes! 6.0 liters of love.
Old Dec 20, 2021 | 06:17 PM
Utinator's Avatar
Does anyone have a photo of Steve's work? I might consider trying it too.
Old Dec 21, 2021 | 01:17 AM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default 5.3 breather hole
Here you go. The hole I drill through is identical in size and location to the holes on the original LS1 block.
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Dec 22, 2021 | 08:57 PM
Utinator's Avatar
Why is there a hole in the end, just under the cam bearing plate area? It looks like it could sling oil out.
Old Dec 22, 2021 | 09:31 PM
spanks13's Avatar
how else would you drill the other holes?
Old Dec 22, 2021 | 10:24 PM
I don't think he thought the question all the way through.....
Besides, it should help lube the cam chain and sprockets
Old Dec 22, 2021 | 11:06 PM
LS1TECH Sponsor
Default Breather hole drilling
The front three bulkheads are drilled through the front of the block. The block is then reversed to drill two matching holes from the back of the block. This takes roughly three hours of set up time and machining. Also a photo of a factory drilled LS1 block being machined for MID sleeves many years ago showing the same hole in the front of the block. You would need a huge machine to drill from the back avoiding the front bulkhead. Even GM didn't do it that way.
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
Old Dec 22, 2021 | 11:35 PM
Which operational circumstances would most benefit from "bay windows"?
I can see converting Gen IV aluminum 5.3L blocks to LS6 specs via this operation and boring to 5.7L spec. Usable LS6 blocks are getting rare.
Old Dec 23, 2021 | 08:01 AM
Utinator's Avatar
I was thinking about using a small angle grinder with a short drill bit, then a small burr. I'm not sure how much room is in there though. I don't have a big enough drill to go in from the ends.
It just looks like the holes in the end would allow oil to get into the front and back covers. I know those covers can leak, and I wouldn't want to encourage them more. I probably won't try this after all. It looks like something that is better left to the professionals.
Old Dec 23, 2021 | 08:22 AM
Double06's Avatar
Steve - I thought I read somewhere you thought the hole drilling was worth about 10 hp on a NA motor.
