NA C5Z Build
Old Aug 7, 2023 | 09:54 AM
  #81
02EBC5Z06's Avatar
So while I still wait for the trans to be finish assembled (my guy was getting it together and found that the output shaft liberty sent him was not for a corvette since it was about 6" shorter lol)... I decided to play a bit with Desktop dyno. I think it is a little bit optimistic, but how much, not quite sure. This is flywheel numbers obviously. I feel that it should peak a bit higher (closer to 7500 or so) but I would be fine with this curve if it comes down to it.
Old Aug 9, 2023 | 12:25 PM
  #82
Ryans99ls1's Avatar
looks about 760peak, and with a 12% loss, has you 660ish to the wheels. You have a nice build but idk if its enough to put 660 down.
I don't feel like digging up what I did a few months ago, but i sim'd my setup (not on desktop dyno) that i just took out of the car and it was about 50hp high on the fllywheel estimate compared to track times and the dyno curves i had. It nailed the shape of the curve though, so that was cool.
Old Aug 9, 2023 | 12:30 PM
  #83
02EBC5Z06's Avatar
Oh I 100% agree lol. Realistically I see this thing maybe being 700-720 crank at most. Which would be like 610-630 wheel.. Even then, 630 will probably be a bit much. I'd put my eggs in the 600-615 basket probably. I did this mainly for the curve as well. I feel that it will probably peak further to the right (7500ish).
Old Aug 9, 2023 | 07:39 PM
  #84
jayyyw's Avatar
I believe it'll make every bit of 530whp
Old Aug 9, 2023 | 07:46 PM
  #85
02EBC5Z06's Avatar
Well if Mines making 530.. Yours is making 670 🙃
Old Aug 9, 2023 | 07:53 PM
  #86
jayyyw's Avatar
Big oopf
Old Aug 11, 2023 | 07:05 AM
  #87
Double06's Avatar
I think they did a build similar to this in a magazine (408 I think) and it was like 708 hp (around 7,000 rpm) and tq was like 577 (at like 5,500 rpm).
Old Aug 11, 2023 | 07:13 AM
  #88
02EBC5Z06's Avatar
I would love to see that article if you can remember what magazine it was. But I think that is very realistic.
Old Aug 11, 2023 | 08:47 AM
  #89
02EBC5Z06's Avatar
Unless it is the Borowski 408 they did for that sweepstakes. It made 717/608 with a fast hi ram and RHS LS3 heads. Less compression than mine and it peaked at 6800.
Old Aug 11, 2023 | 08:54 AM
  #90
02EBC5Z06's Avatar
They did another similar 408 that made 740hp/625ctq. Once again, these are all ls3 headed/fast hi ram. But all peaking in the mid to high 6k range.
Old Aug 12, 2023 | 11:05 AM
  #91
02EBC5Z06's Avatar
Actually, pretty sure it was @speedtigger 403 motor.
Old Aug 12, 2023 | 11:34 AM
  #92
Call Cam Motion. "Speedtigger" works there.
Old Aug 12, 2023 | 12:07 PM
  #93
Bspeck82's Avatar
im building a 403 llsr as we speak. should have results in a month or so.
Old Aug 12, 2023 | 12:17 PM
  #94
02EBC5Z06's Avatar
Anymore details on it?
Old Aug 12, 2023 | 12:25 PM
  #95
Bspeck82's Avatar
Sure,
403 ls2 block, 12:1 scr, tfs (tea) 255 ls3 heads, llsr 246/266 111 680 cam. ported fast mid length runner, crower shaft rockers, comp needle bearing solids, *1237x springs, manton rods, mega mouth ssra ram air kit. No PS, AC or PB. Pulled maybe 300lbs out of the car.
Old Aug 12, 2023 | 12:54 PM
  #96
02EBC5Z06's Avatar
Sure,
Definitely will be a stout combo. I feel that maybe the cam duration could be a bit more being a solid roller? Straight up specs are bout the same as mine at 244/266. I think mine could have used some more lift but that was Brian's decision lol. Are you running the 255s out of the box?
Old Aug 12, 2023 | 01:12 PM
  #97
Bspeck82's Avatar
How much lift does your cam have? Yes the 255s are out the box but milled to 63cc.
My cam was designed with the intention of shifting @ 7500ish. Peak at 6800 to 7000.
Old Aug 12, 2023 | 01:29 PM
  #98
02EBC5Z06's Avatar
Originally Posted by bspeck82
how much lift does your cam have? Yes the 255s are out the box but milled to 63cc.
637/637
Old Aug 12, 2023 | 02:13 PM
  #99
Bspeck82's Avatar
637/637
Stock rockers?
Old Aug 12, 2023 | 02:23 PM
  #100
02EBC5Z06's Avatar
Stock rockers?
BTR stock rockers, btr shaft kit. Johnson st2126lsr, manton 11/32 rods
