Possibly ordering a GM Performance 495 LS engine
If anyone is familar with this particular crate engine, what is the best way to void its warranty while offering more power and longevity? I notice all of GM's crate motors have cams with low lift vs. being over .600's. Can I select a cam to work with this exact platform low lift but extract more HP from doing so?
This motor also doesn't detail, Timing set, Oil pump, Springs used etc... So what is needed? The LS376/480 Long Block is the powerful LS3 6.2L power coupled with:
- L92-style rectangular ports
- High Lift Camshaft (.525” intake/.525 exhaust)
- LS376/480 HP Long Block – 495 HP @ 5,750 RPM / 473lb.-ft @ 4,500 RPM
- LS3 – 436HP @ 5,900 RPM / 428 lb-ft. @ 4,600 RPM
What’s Included
- Fully Assembled GM Long Block
- Oil Pump, Pickup, and Camaro Oil Pan
- Will require L92 style intake manifold, fuel rails, injectors, exhaust manifolds, throttle body, EFI controller, and accessory drive.
- Coolant Crossover, Oil Dipstick, and Tube are not included.
For the typical ~3500 pound car, the GM Hot Cam was a lousy choice for an LS1 back in the day and in my experience is still an extremely suboptimal cam choice for an LS3.
I'd consider the GM crate LS3 and having Cam Motion or other reputable vendor suggest the best cam swap for your goals and combination. Assuming buying a new GM crate motor only to void its warranty isn't an issue.
I don't want to void the warranty per se. But you can't source ls3 these days.
5th gen camaro ss.
I want close to 500whp and back on the road.
Is the L94 an option with healthy cam and ls3 top end? They are cheap vs. Ls3 options.
Also might have sourced an Ls7, but needs sump conversion kit..
5th gen camaro ss.
Of course that voided my warranty but it is what it is. I'm in it for power and not a daily driven LS3. Long term goal is to make it a forged 418 stroker so I'm not too worried either way
I went with the ls7.
. Now while its winter i am looking for head options. Makes pretty damn good power as is. 562whp Well its got the cam which is reported to add 65hp. I have an air intake, stock ls7 manifold, long tube headers, and 25% reduction balancer along with custom dyno tune. 562/509 on hot humid day.
Stock ls7's anywhere from 440 to 460. Check out RPM Youtube they specialize in C6 Z06's and other GM late models.
I placed a claim for itemization with pictures. Guess what denied!! For the fact it was accepted at delivery. It was delivered offsite to my brothers biz.
I imagine much worse for any head or engine damge due to use.
