Trying to make 600 hp plus
Pull a stock 200,000 mile motor out of a $500 rusted out pickup truck.
Stack an inexpensive mid size turbocharger on the exhaust manifold, Push 12 pounds of manifold pressure: Boom 600 horspower the easy way
BTR Stage 4 Truck Cam V2 BTR32430090
Fits 1999-2013 GM LS-Based Engines 4.8L 5.3L 6.0L 6.2L
224/230 .553/.553" 109LSA, 3 Bolt Pattern
This one I like...
BTR LS3 Stage 4 Camshaft v2
Camshaft Duration: 233/25X
Valve Lift with Factory Rocker Arm Ratio: 0.636 int./0.636 exh.
Lobe Separation (degrees): 113
Camshaft Gear Attachment: 3-bolt
BTR Stage 4 Naturally Aspirated v2 Camshaft For LS7 Engines
Camshaft Duration: 246/26X
Valve Lift with Factory Rocker Arm Ratio: 0.662 int./0.662 exh.
Lobe Separation (degrees): 111
Went to mamo Tfs260 ls7 heads, mamo atomic intake, commotion 255/269 solid roller cam , on 93 gas it made 649rwhp
on e85 it made 683rwhp
The latest works I had mamo go his biggest on the heads, titanium valves, jesel keyway lifters, Mamo specced 258/272 solid roller cam on 93 gas it makes 671rwhp N/A on e85 it makes 707rwhp N/A
Ls3 heads are lazy, you’ll need a huge cam, and still won’t get 600
Better heads, great intake, big cam should get u there. Talk to Tony
My camshaft is a CamMotion 243/251 .661/.633 115+4
Most importantly, get a high ram style and you'll make big HP and still have tq with the stroker. Imo, long runner stock alike intake are wrong for anything thats too modified or chasing a number.
. Worked until #7 exhaust lobe took a dump, 2nd CM cam that failed on that same #7 exhaust lobe. It was improper heat treat that caused the 2nd failure, and probably the first, too. I know, because I checked the lobe on our Rc tester. 32Rc isn't gonna cut it for hardness. Cam had plenty of low end and midrange, but remember, not apples to apples as my engine is a 427, though a 408 is pretty close......Last edited by grinder11; Oct 26, 2025 at 11:16 AM.
here's one... 403 N/A build - Page 2 - LS1TECH - Camaro and Firebird Forum Discussion
And scroll to post 21 for results
