LS7 a 7.0L
Originally Posted by Sabre002
That intake and TB sure look like LS2 parts
https://ls1tech.com/forums/showthrea...ght=LS7+Intake
Here's pics of the LS2 Intake.
http://www.eadperformance.com/ls2
As you can see the intake manifolds are easy to tell apart.
Originally Posted by Mr1970Chevelle
First it was a C5R block, now it's an LS2 Intake and throttle-body...
Damn pessimist.
Damn pessimist.
The LS7 intake from the link
LS2 Intake from the link above
Shot from the CTS-V on the 1st page!!!
I stand corrected looks like the LS7 one to me!
Adkoonerstrator
EVERYONE wondering what block or intake that is from here on out just go back and read any post by "LOUIS". The boy KNOWS what the hell he's talking about.
Yep, He knows his Stuff AND he knows what he sees.
Originally Posted by number77 what other pics are you holding out on us chris?
BTW, look at this pic again:
Some of you have probably already noticed this, but you can see the cam sensor between the water pump and the balancer. It's just one more thing that says "gen 4." Also, the motor plate/timing cover that they used is just too cool looking. The dry sump isn't half bad either.
All the talk about the new LS7 Z06 motor being a 427 cid 7 liter motor is still very speculative and we will not know for sure until GM makes the offical anouncement in Jan. 05. For my money, and i hope i'm wrong, its going to be a 6.4 liter motor, making about 500 to 525 crank ponies, in a 3000 lb z06. The good new is that no matter with the displacement is this baby is GONNA ROCK as it seem like it will certainly be at least 500 ponies in a super lite car and should finally put GM back on top
, at least for know, bc you no darn well MOPAR is gonna answer with a new radical motor for the VIPER, etc!!!
Originally Posted by VINCE
My bet is on a 6.4L motor. I have seen 6.4L in too many places..
Originally Posted by Fulton 1
But, then why would "7.0L" be cast into the block? Louis has pointed out several times that the CTS-V race cars DO NOT use a 7.0L. No other GM's use a 7.0L either save for the C5-R, which clearly uses a different block. What would be the point of casting "7.0L" into a block if you're not going to use it with a crank making it 7.0L?
Adkoonerstrator
Originally Posted by Louis
I Place my life on the line that it is a 7.0L
You can throw tomatos later if Im wrong
This is my speculative .02 It's clear that GM has a 7.0L block ready and stout enought to run in competition. Why would GM release a all new 6.4L Z06 Corvette ($50,000++) and also a 6.4L GTO (30,000+). GM has always been very protective of the Corvette. They always underrated the Camaro and Firebird for that same reason. To me it sounds that GM can do 1 of 2 things depending on market conditions.
1. Release a LS2 GTO next year along with the 6.4L Z06 and wait to see how the market reacts slating the 7.0L Z06 for the following year.
2. The C5 and GTO get a 6.4L next year and Z06 gets the 7.0L engine.
Seing GM previous decisions I'm leaning towards the first option.
Please do dot flame me this is just my observation and are not based on any real facts as I have not done any research on the subject.
