Track Results of LS2 Intake
Did you smooth the intake ports on the manifold? Mine were very 'edgy' where the intake was assembled. I smoothed all 8 ports, made them a nice transition.
I hope to have back to back dyno numbers within 2 weeks, and a track visit on the 11th. I plan to take the LS2 intake with me to the dyno, and do the remove LS6 / install LS2 while strapped down. That is, if I can ever get it all together.
I'm hoping to see 10-15 rwhp over the LS6 / Ported TB that I have on my solid roller 383.
We shall see soon as I can get hold of another intake or two to play with.
I certainly hope your results are better than mine!
Brad
Talked to my tuner and he is more than happy to accomodate the testing.
Whats the catch? Gotta wait 2 or 3 weeks
Brad
AFR was fine all the way to 6600rpm. It was very rich on the first pull with the tune for the ls6 intake.
Did not check the duty cycle though I believe they would be close to maxed out. I plan on upgrading soon.
Brad
90mm TB, intake ..........5/3/04 7.199 95.79 1.571 3.90 PT4000
These are my gains in the 1/8 with the LSX. I gained 20HP and have seen the LSX on 346cubes do it regularly.
A noted tuner tested the LS2 vs LSX as making 20HP less N/A and more on FI. Can't remember how much. If logic follows then the worst that you should have done is no gain. Somethings wrong.
It was tuned with this intake on it. It had to be leaned out to make more power.
It is hard for me to believe that the intake would cause such a loss in power.
But there is nothing else that I can find wrong with the car.
Brad
On the LS6 intake, the inlet ports (inside the manifold) are "trumpet" bell shaped. On the LSX and LS2, they are more square. And the 3-piece nature of the LS2 is quite obvious in how it's fitted together - a lot like the LSX.
Tuned it with the stock descreened MAF. Changed it out a week later and let it learn the new MAF and went back to the dyno.
After tuning with the new MAF we picked up more power.
Which leads me to believe this intake is not flowing what it should.
Brad
I've been all through 4 different LS intake styles. I personally only chose the LS2 because of its price and the 90mm inlet. Mine has been completely modified, so I couldn't really compare it to another for 'fair' results. I got rid of the crummy 3piece mating issue with a lot of filling, welding, and sanding throughout, along with the 'straighter' runner issue with some cutting and remodeling of the runner inlets (now tapered).
I spent a couple yrs doing overbores and port work on throttle bodies and intakes before getting deeper into the fab business. Though I eventually got out of it, I still have most of the machines. If you'd like, you can send your 75mm unit this way and I'll set it up for you and the test. Just plan for 4 days turn-around for modifications and shipping. In any case, the end results will be interesting.
plenum volume, runner length, runner volume
I want to compare them to the LS1 and LS6 intakes.
