Track Results of LS2 Intake
In any case, that was no issue in the LS2 testing. In any case, ported TB/LS6 for me until I decide that 20hp is worth $1100.
THE AIR/FUEL WAS TUNED on the dyno with a wideband, meaning the fueling was correct. There are not that many things to adjust at WOT. It's not like part throttle drivablility tuning, which takes much more work. The bottom line is this intake didnt perform!
Brad
Brad
Brad
Exactly..
I thought I would give you some time to comprehend.
And my testing will begin soon enough on a larger C.I. LS2 so we will see.
Brad
So what are you going to do with your LS2? Are you willing to "rent it" if you not using it. I was going to buy a set up until I read this. I would like to try it on my car and see if I get any better results.
LOL I cant even afford coal for my stocking. That intake is long gone man. Sorry.
Brad
No problem man. I have a feeling it will work out alot better for you
Brad
Brad
I'm intersted to see what #'s SCPC comes up with. They're supposed to begin testing them eoy or first of next year. Kris still says they're the way to go? Guess we'll see.
). My car's in the garage, my air compressor's out in my shop... gotta move the air compressor to the garage to get to the Mez to grind it. Uggh.
Got to solder the other half of the MAP wires, fab up a throttle cable bracket & nitrous switch bracket, fit/ cut the Fernco coupler, and then I'm hoping to hit the dyno with it on Saturday morning. I'm going to take my LS6 intake, and swap while I'm on the dyno (that's the plan).
