Track Results of LS2 Intake
I don't know the exact set up of your car; but it almost sounds like...now that the engine is breathing easier, it's not pulling exhaust....have you tried adding or reducing backpressure? what type of exhaust are you running?
just a thought..
Jaybo
Brad
just a thought..
Jaybo
Brad
Brad
break em loose and see if it helps? worth a shot...
keep me informed..i'm curious as Fxxx now!
Looks like I may have time to do some testing with an LS6/PTB as well.
Brad
The problems with the FAST TB were not in the power department. I originally had a FAST TB on it. Now I have the TPIS 90mm. Much better quality.
When the LSX goes on tonite I will have about 100miles or so on it befor eit goes on the dyno for tuning. With the LS2 I had about 400 miles on it before tuning.
When I change out to the LS6 on the Dyno I will not be able to put that many miles on it between the swap. But we will tune for max power with each intake.
If the LS6 works out to be better I will just get a 78mm top for the LSX sell the LS6 n call it Christmas. Then I will already have the 90mm TB and top for when I upgrade in a few months. If I dont need it then I will sell it.
Brad
The reason I ask is, I just got mine from KJ@SDPC and the front coolant tube is holding the front of the intake 1/4"-1/2" up from seating.
And on top of that, if it does seat, I dont think it's gonna clear the corner of my Meziere water pump...
Just tap it down lightly with a hammer to get it to bend slightly out of the way. Hopefully it will clear your WP.
What TB are you using?
Brad
Stay tuned while I get tuned! Numbers will be up this afternoon
Brad
Red Is the LS2 and Blue Is the FAST.
Used the Same TPIS TB. Only change was the intake. These are the max power numbers for both intakes.
Same Dyno too.
Track on Sunday!!!
Brad
