LS2 402 short block at SDPC!
Old Jan 29, 2005 | 10:32 PM
  #181
KJ's Avatar
KJ
Originally Posted by Lostpatrolman
Seems like everythign ls2 specific is supplied with the shortblock. Everything other then the parts supplied should interchange with ls1 stuff.
That is correct!! I provide everything you will need to make the change. Front cover, timming set & valley cover will ship to you UPS. We have tried to make this as simple as possable!
Old Jan 29, 2005 | 10:57 PM
  #182
INSOMNIAC's Avatar
Arrow
Kris,
I sent you a PM about the custom LS2 402 short block I need.
Waiting for your quote.
Thanks,
Old Jan 30, 2005 | 11:06 AM
  #183
ls1/7's Avatar
Originally Posted by KJ@SDPC
The LS2 402 in my opinion would be the way to go. The weight difference of an iron block in a Corvette makes it handle a little different. Just about all the mods you can make on a LS1/LS6 can be made on this LS2. The main difference is the valley cover, front cover, and timming set.
We have a customer that completed one of our 402 short blocks with a set of Lingenfelter CNC ported LS6 heads (65.5cc) & a GM grand cup cam, compression is about 10.8. I believe it made somerwere around 570hp & around 515 ft lbs of torque. He was using the LS6 intake and a ported tb.
any chance on getting a dyno sheet and specs on his car? WOuld sure push me to get one
Old Jan 30, 2005 | 04:24 PM
  #184
amwellls1's Avatar
were those numbers to the wheels, what type of dyno? Graph would be awesome!
Old Jan 31, 2005 | 09:08 PM
  #185
KJ's Avatar
KJ
The dyno was done on an engine dyno. Last time we talked he said he was going to fax me a copy of this dyno. I will follow up & find a way to post it.
Wanted to let everyone know that I found out that the LS2 block uses it's own lifter guide. The lifters are the same just the shape of the guide is a little different.
Old Feb 6, 2005 | 11:56 PM
  #186
Lostpatrolman's Avatar
so can ls1 lifter guides be used, or do we need the ls2 ones?
Old Feb 7, 2005 | 06:28 PM
  #187
89FormulaLS2's Avatar
I spoke with Kris today, and he said they have even come up with a solution for the knock sensor problem, to allow using the LS1 knock sensors.
Looks like I'm gonna be ordering an LS2 402 before the week is out!
I'll probably upgrade the crank and rods though - I can see a turbo kit in the future as well.
Old Feb 7, 2005 | 06:29 PM
  #188
V-10 Killer's Avatar
That's definately good news!!
Old Feb 7, 2005 | 06:46 PM
  #189
KJ's Avatar
KJ
You have to use LS2 lifter guides. The block casting is different
It's hard to see in this picture but look just above the end cylinders and you can see it. I will try to find a better picture.
Old Feb 7, 2005 | 06:51 PM
  #190
KJ's Avatar
KJ
I have been trying for days to find time to get on here and tell everyone about this. We had the chance to dyo a stock LS2 with a Magna Charger on it. The realy cool part is The calibration manager from Magnuson came down to tune it on our dyno. We used stock LS6 knock sensors & put them in the motor mount holes. You could drill & tap the original hole for the LS2 knock sensor & it would work just fine.
Old Feb 7, 2005 | 09:05 PM
  #191
93Polo's Avatar
Great news Post some pics and dyno #s on the LS2 mag when you get a chance.
Old Feb 8, 2005 | 10:30 AM
  #192
JS's Avatar
JS
Kris how do u use the motor mount holes if your using them for the KS?
Please explain alittle better?
Old Feb 8, 2005 | 10:41 AM
  #193
GuitsBoy's Avatar
Kris, how much for just the block, front cover, timming set and valley cover for those of us who wish to build it ourselves? Also, what condition does the block come in, meaning what machine work is required? Align hone the mains, final honing the bores, and the balance? Thanks for all the help. This is great news about the knock sensors.
-Tony
Old Feb 8, 2005 | 11:41 AM
  #194
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Whats a 408 Iron block setup cost in comparison?
Old Feb 8, 2005 | 12:09 PM
  #195
JS's Avatar
JS
J-Rod I believe its basically the same price....
Old Feb 8, 2005 | 06:45 PM
  #196
Slowhawk's Avatar
LS1Tech Sponsor
There is 6 holes on each side of the block.4 are used for the mount and the other 2 are free/open.
Old Feb 8, 2005 | 08:00 PM
  #197
Ordered mine today!!
Old Feb 8, 2005 | 08:21 PM
  #198
DrkPhx's Avatar
Cool. what heads, cam and intake are you plan on using?
Old Feb 8, 2005 | 08:50 PM
  #199
P Mack's Avatar
So you put one on each side? Top or bottom?
Old Feb 9, 2005 | 02:01 AM
  #200
I've got a set of LS1 heads that were hand ported and milled .050 that flow VERY VERY well, and I'll use an LS6 intake. Not sure yet on the cam - looking into that now, might even have a custom cam made up for my setup.
