LS2 402 short block at SDPC!
When can we expect to see those SDPC catalogs ?
Having the knock sensor extension wires and cam sensor will be a great help. I'm sold !! Just need to get the $$$$ saved up.
BTW.... What heads and cams are available ? AFR 225 ? Anybody can feel free to respond to this one.
THANKS !!
*LS2 aluminum block
*Eagle 4.000 stroke crank
*Crower 6.125 I beam rods
*Diamond -2cc flat top pistons
*Diamond file fit rings
*Clevitte "H" rod & main bearings
*Durabond cam bearings
Also will include: LS2 front cover, valley cover, and timming set.
$4,095.00 + shipping!!
I must have missed something somewhere.
Please post the link to the thread that explains how the use of knock sensors on a LS2 block while using a LS1 computer works.
Someone must have spent countless hours on a engine dyno to figure out that it would work....
Bill
Bill
The knock sensors can be mounted in one of the two unused tapped holes next to where the motor mounts attach. The ping's sonic signature is close enough there to trip the knock sensors.
But seriously, yes, its been tested on a dyno, but not by me personally as i cant afford my 402 yet
Do some searches on "402 + Knock Sensors" and youll see some reports. You will have to adjust the sensitivity of the knock sensors when your tune is done. Just like Guitsboy said, the factoy setting will not do the job!! Most tunners out there have worked with an LS2 by now, so tunning should not be an issue.
Edit: After some searching, should I expect around 520rwhp give or take?
