LS2 402 short block at SDPC!
Old May 19, 2005 | 01:12 PM
  #321
Rottluver's Avatar
Originally Posted by Ed Blown Vert
Visually I didn't think it would be an issue. I am more worried about the sniffer.
Understandable, but if you stayed away from a super aggressive cam, I "think" you would be ok. I believe I read several pages ago that SDPC is building one now for a Vette in Cali.........anyone???
Old May 19, 2005 | 01:16 PM
  #322
Ed Blown Vert's Avatar
But what is an aggressive cam in a LS2??
My 224 is way small I am sure. I need to get a blower cam anyways.
Guess I'll call them....
Old May 19, 2005 | 01:22 PM
  #323
Rottluver's Avatar
Yeah I have no idea there.......I think you are right on the money with calling them. Although, and I am just guessing here, isn't a blower cam slightly milder then an aggressive street (N/A) cam? So that would work in your benefit (providing it is correct).
Old May 19, 2005 | 01:41 PM
  #324
I called them, they are checking to see if anyone smogged it.
I think a blower cam is a split duration with a 114 or 115
Old May 19, 2005 | 01:52 PM
  #325
Rottluver's Avatar
Hopefully they will have good news......your car is a flippin beast now, I cannot even begin to imagine it with one of these blocks.
Old May 19, 2005 | 01:57 PM
  #326
If not, I will just go with a forged 347.
A reliable 600 rwhp would be nice. :p
Old May 21, 2005 | 09:16 AM
  #327
04Yukonxl's Avatar
How much for a stroker kit for current LS2 owners?
Old May 22, 2005 | 10:23 PM
  #328
MakoLS1's Avatar
whats the difference between the LS2 aluminum block and LQ9 iron block? Are they basicially the same inside and out except that one is iron and the other aluminum?
Old May 25, 2005 | 05:10 PM
  #329
KJ's Avatar
KJ
We can do this!! We have everything in stock. This is what we can do:
*Eagle 4.000 stroke crank
*Crower 6.125 Sportsman rods
*Diamond -14cc dish pistons
*Diamond file fit rings
*Clevite rod & main bearings (H)
*Durabond cam bearings
*Balanced
TOTAL $2,299.95
We would be happy to change this kit to fit your needs. Just give me a call or pm, and we will work out the details!!
Old May 25, 2005 | 05:21 PM
  #330
KJ's Avatar
KJ
The 6.0 iron block is a little different than the Aluminum LS2 block. The LS2 block requires side mounted knock sensors, front cover with cam sensor in it, and you can only use the single row timming set for the LS2 from GM. The LS2 block will only bore to 4.020 (thats what GM says), and the iron block will go 4.060 (you will want to sonic check it before you go that far).
Here is the only pic I have of the LS2 block.
Old May 26, 2005 | 03:50 PM
  #331
stealth71's Avatar
KJ-
I have a 71 Chevelle that is in need of a new motor. I am interested in a iron 6.0L w/ the callies crank and rods. I want to build something low compression 8.5:1, so I can turbo or supercharge it down the road. This will be a carbureted motor using this manifold: http://www.edelbrock.com/automotive/man_chevy_ls1.html
I am hoping for 500hp NA until I buy a turbo when the bank replenishes. What is the going rate on this short block? Do you think there is anything else I need for 700hp?
Thanks,
Mike
Old May 26, 2005 | 04:14 PM
  #332
NOSjohn's Avatar
Restricted User
The 500 crank HP might be hard to attain with 8.5:1 compression. Even with great heads a healthy hydraulic or solid cam, it might just be touching on the 400hp mark. Good idea on keeping the compression low however for your future endeavors. Sounds like it will be nice in a Chevelle.
Old May 26, 2005 | 09:01 PM
  #333
stealth71's Avatar
After reading the right up on the RAPID 553 rwhp monster I think that is what I'm looking for. How much will that bottom end cost me with an iron block, ready for nitrous. I've been wanting a turbo for a while but the budget is saying pump gas and nitrous. Thanks
Old May 26, 2005 | 09:06 PM
  #334
DrkPhx's Avatar
Around $3500 for a iron block 402. Call Kris at SDPC and he will hook you up.
Old May 26, 2005 | 09:10 PM
  #335
MakoLS1's Avatar
Its about $3600 for the iron block 402. Then add $380 for a nice custom cam. $115 for a decent timeing chain. Which has to be bought seperatly. All and all with good tuner and decent heads and good cam upper 400 to somewhere in the 500rwhp on motor shouldnt be to hard. Its about 80ish pounds heavier which is the only down side but its not a huge deal. Also, Kris J. has been really good to work with.
Old May 27, 2005 | 09:53 AM
  #336
KJ's Avatar
KJ
KJ-
Thanks,
Mike
Mike,
I sent you a pm!! We would be happy to build you an iron 402. We have JE pistons on the shelf that we had made just for our turbo motors. They have a -34cc dish and are only .002 out of the hole. We also had them built with a 1/16, 1/16, 3/16 ring grove to accept our Akerly & Childs "Hell Fire" ring package. Let me know if I an get one started for you!!
Old May 27, 2005 | 10:15 AM
  #337
KJ's Avatar
KJ
I wanted to let you guys know that I will be gone on Hot Rod power tour from Thursday the 2nd and will be back at work on the 13th. I am hoping to be able to get online from time to time to answer pm's. When I get back I plan to post all of our options that we have for our 402 and what the prices are. If anyone plans to go on the tour or can make any of the stops be sure to come by the Flowmaster booth. I will be there handing out free catalogs, and I hope to have a special or two for any of the LS1tech members that I see.
Old Jun 15, 2005 | 08:44 AM
  #338
KJ's Avatar
KJ
Well guys I'm back and I'm glad. Nothing like 4,800 miles round trip in a weeks time Anyway, I wanted to let you guys know that we have yet a few more options for you. We have just recieved a pallet full of Lunati cranks and there NEW "Pro Mod" LS1 rods! One or both would make a very nice upgrade! We have also used these parts to complete our "boost" motor along with our custom JE pistons. Here are the specs on that short block............
Check out our new LS2 402 that is 100% ready for lots of boost!!
**LS2 block with all oil galley plugs & dowel pins
**JE -34cc dish light weight piston .927 pin
**Akerley & Childs "Xtreme" rings ("Hell Fire" 1/16,1/16,3/16)
**Lunati pro mod 6.125 "LS1" rods (new, just released)
**Lunati pro series 4.000 stroke crank 4340 forged steel
**Clevitte "H" main & rod bearings
**Durabond cam bearings
**ARP main studs
Also included:
**Front cover (includes cam sensor, gasket & bolts)
**Valley cover, gasket & bolts
**LS2 timming set
**Shipping crate & stand
Balanced, bluprinted, and assembled ready to ship for $5,399.95
Pricing update on SDPC LS2 short block
We have raised the price on our short blocks $100.00 so we can include a metal stand and a shipping crate. The reason for this is fear of them getting damaged in shipping. We were using the original block crate, but have found out the hard way on one that this is not the safest way to protect your investment. Keep in mind you are still getting the best bang for the buck at SDPC! We still include front cover, valley cover, and timming set in this price.
LS2 402 with -14cc dish pistons new price $4,095.00
LS2 402 with -2cc flat top pistons new price $4,095.00
Please pm, email, or call me with any questions you might have.
Old Jun 28, 2005 | 02:26 AM
  #339
WICKED SS's Avatar
sent you a pm
Old Jun 28, 2005 | 09:10 AM
  #340
Z06PSI's Avatar
That is a great deal on that motor..... 422 hmmmm......
