ls2 lifter trays?
Old Oct 12, 2005 | 11:18 PM
A Mustang's NightMare's Avatar
Default ls2 lifter trays?
well I started assembly of my new ls2.And the lifter trays dont feet,does the ls2 have different trays?
also where can I get Ls2 head bolts?
and is there any other stuff I need to know?
Old Oct 12, 2005 | 11:32 PM
jhong321's Avatar
How is it going? I just finished with mine about a week ago and there are a few things you need to know about.
Yes you need different lifter trays you need to order them from gm and will take a couple of days to get them the good news is they are cheap 5.00 per tray
You can also order the head bolts from GM.
Check your windage tray for clarence. Mine did not clear and i had to add a washer to it but i had the corvette oil pan I am not sure about yours.
You will also have to relocate the cam sensor and knock sensors
You can get the extensions from ractronics for about $60.00
I think thats about it
Good luck
Old Oct 12, 2005 | 11:51 PM
Black8Banger's Avatar
crap, you need new lifter trays?!?! Im right in the middle of putting mine together and looking at those trays was one of the next things on my list.
On my rear cover I had to put a washer on the bolts bc my stock bolts bottomed out b4 the cover was tight...not sure if it was just my luck or if anyone else had this problem.
Old Oct 12, 2005 | 11:53 PM
bro the bad news is that I had allready bought new lifter trays.
but oh well I buy the new ones.
thanks I'll order everything ASAP. Well good luck with your set up
Old Oct 12, 2005 | 11:55 PM
I havent being there yet, But in my case I'll just make a trip to osh and buy new bolts
Old Oct 12, 2005 | 11:57 PM
jhong321 are you planing to take your car to sac?
Old Oct 13, 2005 | 12:02 AM
where exactly do those knock sensors go in the ls2 block...i was thinking about just not having them!
did your ls2 block come with new plugs or did you use the ones from the ls1 block or buy new ones?
Old Oct 13, 2005 | 12:04 AM
jhong321's Avatar
There is a couple of good spots for them on the side of the block
motor mounts (hte unused bolt hole and another one by itself near the back.)
Old Oct 13, 2005 | 12:06 AM
jhong321's Avatar
As soon as i get it tuned i will be there on a wendsday Do you go up much? I go up there with a few friends one with a ws6 and the other with a zr1 I use to go there with my old ZR1. Maybe i will see you up there
Old Oct 13, 2005 | 12:08 AM
jhong321's Avatar
The windage tray is a common thing I have heard people ethier shim it or use a ballpinn hammer. I did both just incase
Old Oct 13, 2005 | 11:35 AM
nasty ss's Avatar
Maybe I am missing something, but ls2 lifter trays work with ls1/ls6 lifters and vise versa. The ls2 trays are a better design. I have been putting them in every head/lifter swap car so far and they are great!
Old Oct 13, 2005 | 06:59 PM
DrkPhx's Avatar
The LS1 lifter trays do not work with the LS2 block. You need the LS2 trays to fit.
Old Oct 13, 2005 | 08:25 PM
gojo's Avatar
Thanks, it's added.
If you go to an LS2 block these are the LS2 parts you will need. The remaining LS1 parts work.
Lifter retainers
Valley cover
Timing chain cover
Timing chain and gear
Timing chain dampener
Cam sensor and electrical connector
Tap block for LS1 knock sensors
Plug PCV outlets on rear of each valve cover(2)
Run PCV lines per LS6
LS2 head bolts
Old Oct 14, 2005 | 09:54 AM
how about head bolts?
I'm still using my old ls1 heads. and bolts are to tall for this heads
Old Oct 14, 2005 | 10:03 AM
Yea after I'm done with my car I'll go often.sometimes I'll go and see my friends running.
Hopefully we can meet sometime
Old Oct 15, 2005 | 12:42 AM
jhong321's Avatar
i also forgot to tell you about the motor mounts on one side of the ls2 will need to be filed down to fit the c5 motor mounts. let me know when you are done we can meet some time and run them for fun or a hotdog (thats what me and my friends run for up at sac.) plus we talk hella crap to each other all in fun of course
btw do you ever get over to corvette forum? we are having a extreem run(a bunch of us get together and raise hell with the bikers down at 4 corners in woodside) we have about 20 of going out this week on the 23rd of this month. if you want to come along pm me.
Old Oct 15, 2005 | 02:23 AM
x phantom x's Avatar
STF veteran / 10 second club
Originally Posted by gojo
Thanks, it's added.
Lifter retainers
Valley cover
Timing chain cover
LS2 head bolts
You don't have to tap the LS2 block to fit the LS1 knock sensors ... there are 2 holes on each side which the LS1 knock sensor can just screw right into. One is near the motor mount, and the second is kinda hard to find but is in the back of the block. Just screw the LS1 knock sensor in, and off you go.
Old Oct 15, 2005 | 10:13 AM
in the back!
I tought one was next to the motor mount and the other on the other side by it self
Old Oct 15, 2005 | 06:56 PM
jhong321's Avatar
in the back!
If you need some ideas let me know you can alway look at my motor
Old Oct 15, 2005 | 10:28 PM
were in the bay are you?
