LS2vsLS6
Old Nov 22, 2005 | 11:53 PM
bluedrago's Avatar
Default LS2vsLS6
I was looking around alot and can't quite find an answer to my question....I was wondering if anybody knows which flows better the LS6 manifold or the LS2 manifold....being as the LS2 is a 90mm similar to the fast 90mm setup but I don't think it flows as well as the FAST manifold....question has nothing to do with FAST .....which flows better LS2 or LS6....anybody??? Sorry if this is a repost I searched and searched and couldn't find me an answer ..... if this is a repose mind directine me to the right link.
Old Nov 22, 2005 | 11:59 PM
NOSjohn's Avatar
Restricted User
One thing you must keep in mind is that these manifolds were designed for specific cubic inch motors. The LS6 for a 346 c.i. and the LS2 for a 366 c.i. On a typical LS1 motor, the LS6 will make good gains, the LS2 will also show a gain but not significantly more.
Old Nov 23, 2005 | 06:32 AM
bluedrago's Avatar
Thanks thats just what I was wondering.
Old Nov 23, 2005 | 12:04 PM
zamboxl's Avatar
not sure about this i have been out of the tech forums for a while but last time i checked the ls2 intake sucked, it was built to be a cheap intake that wasnt that good last i heard the ls6 intake with its smaller opening flowed better
Old Nov 23, 2005 | 12:45 PM
TXNC5's Avatar
You might this interesting.
Here is one test: LS2 vs LS6 on an LS2
Here is another LS2 vs LS6 vs FAST on an LS1
Old Nov 23, 2005 | 01:14 PM
abbaskhan's Avatar
very intresting ...but if you wanted to truly see the differnce you would have to tune the pcm for each intake for best results. by simply bolting on one of the new intakes the test does not take in to account the change in the airflow wich inturn affects your A/F ratios. until thers a comprehensive evaluation then its hard to judge.
Old Nov 23, 2005 | 01:28 PM
zamboxl's Avatar
if u where to do that then the ls6 would shine even more, lets take into account that it not only did better on the ls1 engine but also on the ls2 engine wich is ls2 intake territory.
Old Nov 23, 2005 | 04:09 PM
See5's Avatar
I found out the hardest way that the LS6 is best. Tried LS2, Fast 90 and back to LS6. Without a bigish cam even the Fast 90 is a waste of money. Never heard of a happy LS2 intake user. Maybe FI?
Old Nov 23, 2005 | 04:16 PM
jpolser's Avatar
It is a "cheap" intake only because it is produced in larger numbers across several vehicles (vs. LS6.)
I think the real reason that is it used on the aluminum 6L engines it because it allows "improvement" that will cause people to want to trade up in a few years.
Why do you think it always takes 2-3 years before a car has a decent looking stock wheel that comes standard? If it ain't the looks that draws them in, it is the hp number in motor trend.
To answer the original question, check hotrod.com for their "LS2 dyno flog." The LS6 made more power, and the LSX a tad bit more.
BTW, I am posting under my brothers account. I (gogogadget username) have a 94 Z28 with an LS2, and the intake will be the LAST improvement that I make.
Old Nov 23, 2005 | 10:03 PM
zamboxl's Avatar
yes and no it is produced for more vehicles, and it is also a crapier desing ei cheaper, just like the ls1 was, wich is why after 00 it was faced out for the ls6, just like the ls2 intake will be faced out in a few years. Iam sure they do it just so that in a couple of years they could switch to a new intake, and bump the numbers.
Old Nov 28, 2005 | 12:18 AM
mdhmi's Avatar
I've seen some TT LS1's gain power switching from the LS6 intake manifold to the LS2. The power gain is up high. If you don't have a heads / cam combo that is going to make good power above 6,500 RPM I wouldn't bother switching to the LS2 manifold.
Mark
Old Nov 28, 2005 | 09:46 AM
treyZ28's Avatar
This couldn't be further from the truth.
Old Nov 28, 2005 | 09:49 AM
treyZ28's Avatar
ohh yeah. I would personally guess that manifold is there to restrict power/rpm. I doubt it made less power than the LS6 on accident.
Old Nov 28, 2005 | 10:13 AM
zamboxl's Avatar
Mark
was the ls2 intake port match? thats the only way i seen them out shine or match the ls6 but then again it wasnt of fi aplications, so i wont bouch for them there.
Old Nov 28, 2005 | 10:17 AM
See5's Avatar
I might guess they (GM) put the "new guy" on it and he did not have a grip on the flow velocity concept.
Old Nov 28, 2005 | 12:22 PM
treyZ28's Avatar
extremely doubtful
Old Nov 28, 2005 | 03:00 PM
98_Formula's Avatar
there was a post on here where someone ported the ls2 intake and it outflowed the FAST 90/90 setup in most area... i know ur not comparing the fast intake to the ls2 but i know there was a thread somewhere either here for ls1.com. of course the fast intake was not ported, it was more or less offered as a cheaper route than goin with the fast 90/90
Old Nov 29, 2005 | 04:16 PM
Neumonic2002's Avatar
you really need to ask which one your going to use it on, the LS1/6 or the LS2...on an LS2 I don't think the LS6 intake is an improvemant at all(not worth the time swapping) for an LS1/LS6 the LS2 intake is not designed for either of these motors so it is a no-brainer that it is not a better design.
I think NOSJohn already brought up this point and everyone else must have missed it..
Old Dec 1, 2005 | 10:15 AM
gogogadget's Avatar
Hotrod's "LS2 dyno flog" article proves otherwise.
