Need help Building A Forged 412 LS2
Old Jan 20, 2006 | 10:44 PM
XpEdItIoUs's Avatar
Default Need help Building A Forged 412 LS2
Im going to be builing a 412 ls2 and need help on picking the right bottom end. What will be the best setup for this nitrous motor and what bore/stroke and rods will i need.
Old Jan 21, 2006 | 09:53 PM
XpEdItIoUs's Avatar
Can anyone here help please.
Old Jan 21, 2006 | 09:54 PM
XpEdItIoUs's Avatar
Any sponsores here have what i need to build this.
Old Jan 21, 2006 | 10:34 PM
Builder's Avatar
Without punching a calculator, I am not sure what a 412 is. Most of the sponsors seem to have a 402 AL block, or a 408 FE block, ready to roll. Those you can have with any combination of mild to wild components...and in a week to three, depending on the builder.
Is there a particular reason you are looking at 412ci?
Old Jan 22, 2006 | 09:42 AM
383ss's Avatar
sounds like you need to use the search feature and call some sponsors to see what they will offer for what $$$$.
do you know the bore/stroke combo for a 412?
Old Jan 22, 2006 | 11:47 AM
Randy WS6's Avatar
you can try to build one with this. it might help some
4.00 bore 6.125 rod & 4.100 crank 412cid.
http://www.c5frc.com/calculators/Com...Calculator.htm
Old Jan 22, 2006 | 02:46 PM
XpEdItIoUs's Avatar
Im going with a 412 because it's closer to a 427 that i wish i could afford.
Old Jan 22, 2006 | 03:00 PM
Randy WS6's Avatar
Im building a 418cid aluminum LS2 4.030 bore & 6.125 rod & 4.100 crank.
Old Jan 22, 2006 | 06:04 PM
XpEdItIoUs's Avatar
Where are you getting your rotating assembly from.
Old Jan 22, 2006 | 07:45 PM
Randy WS6's Avatar
Eagle
Old Jan 22, 2006 | 09:17 PM
RAMPANT's Avatar
I'm using:
- LS2 block 4.0005 bore
- Eagle 4.100 crank
- CompStar 6.125 rods
- Wiseco Pistons
Topped off with AllPros heads.
The motor has been quite reliable so far, but has only 4K on it and about 60 passes. I have stayed NA but I'm sure it would be fine with some spray.
Rampant
Old Jan 25, 2006 | 03:36 PM
MyWs62FaST4u's Avatar
im doing a 418 too...
Old Jan 25, 2006 | 03:40 PM
chuntington101's Avatar
well for a 402 i would go for W2W! they say their kit can handle 1500bhp (tested)!!!
good enough for you?!?!?!?!?!?!?!?
Chris.
Old Jan 25, 2006 | 05:38 PM
Randy WS6's Avatar
I got my Eagle Crank 4.100 & Eagle rods 6.125 last week and got my ROSS pistons yesterday and got my aluminum LS2 block back today board .030" looks grate .tomorrow ill put the crank in and rods & pistons to mock up the block to check for any clearance problems with the rods hitting inside the block and grind were needed and disassemble the motor to take to have balanced .not long now!!!
Old Jan 27, 2006 | 10:00 AM
Kevin@W2W's Avatar
LS1TECH Sponsor
In all reality the cubic inch delta will not produce a large horsepower difference.
Old Jan 27, 2006 | 11:06 AM
383ss's Avatar
who did you get the block from? most places I've heard of are leary of doing a 4.030 bore ls2
Old Jan 27, 2006 | 02:56 PM
i agree totally! if you are making 2bhp per ci then you will make about 20bhp more! oh and thats asuming all the efficencies are the same!
Chris.
Old Jan 27, 2006 | 03:50 PM
Randy WS6's Avatar
20 hp is 20 hp ill take all i can get ,for a $90.00 bore job. it hard getting 20 hp out of a big cub. motor for 90.00 ,motors that's had every little bit of hp squeezed out of it with every mod know to man, with cams ,heads ,intakes, computer tuning, n.o.s., turbos, blowers, so all i can think of is got bigger cubs. or as much as a man can afford.What do you think ?????
Old Jan 27, 2006 | 08:51 PM
XpEdItIoUs's Avatar
I heard somewhere that a 4.100 crank puts alot more stress on the rods.
Old Jan 28, 2006 | 10:06 PM
Randy WS6's Avatar
It might on a stock length rod ,But shouldn't as bad on a longer rod like a 6.125" because that it don't come out of the bore as much (binding up in the cylinder) and with aftermarket rod like a H beam there made for the extra stress.
