Warhawk Block?
Old Feb 23, 2006 | 10:22 AM
  #81
WARHAWK~572's Avatar
Originally Posted by 93Polo
Will a carb style intake be offered for the tall deck without using spacers?
Yes.... Use the ls7 carb style intake.... You do not need spacers with this block.
Old Feb 23, 2006 | 10:40 AM
  #82
JL ws-6's Avatar
Race your car!
Will the edlebrock victor jr intake work on these?
Old Feb 23, 2006 | 12:22 PM
  #83
Wet 1's Avatar
The Vic. Jr. intake is not set up for the LS7 ports (if I recall correctly), so it obviously wouldn't work with the WP LS7 style 12* heads. This intake should fit fine with std. 15* heads on a WP std. deck height block. If you wanted to use it on the WP tall deck block, you'd need spacers and again traditional port heads.
Old Feb 23, 2006 | 03:46 PM
  #84
!! You do not need spacers with this block !!
!! It does not matter if it is a standard or tall block !!
12* heads = 12* intake
15* heads = 15* intake
  #85
Old Feb 23, 2006 | 04:40 PM
  #86
93Polo's Avatar
I can't wait to see pricing on this. It'd look at home in a 70 Chevelle
I was referring to spacers between the intake and heads not the block and heads.
Old Feb 23, 2006 | 06:05 PM
  #87
Steve Bryant's Avatar
LS1 Tech Veteran
At any deck height significantly different than 9.240" (my guess would be plus or minus .300"), you would need to either have a different or modified or shimmed intake manifold. The distance between the intake ports of the left and right banks of cylinder heads will grow or shrink with changes in deck height. It's straight geometry.
Steve
Old Feb 23, 2006 | 10:11 PM
  #88
Wet 1's Avatar
I guess I stand corrected... PLEASE explain why you wouldn't need spacers with a taller deck?!?!?!?!?!?!?!?!?!
Old Feb 24, 2006 | 06:22 AM
  #89
Warhawk 1's Avatar
LS1TECH Sponsor
Guys,
Come on, if you move from 9.24" up to 9.8" deck height at 90 degrees you either need spacers, a new manifold or a different hobby
B
Old Feb 24, 2006 | 06:25 AM
  #90
Warhawk 1's Avatar
LS1TECH Sponsor
93Polo,
I am working on developing carbed manifolds for our platforms, yes. ETA is obviously the next question. I don't have an answer as I'm still developing it.
B
Old Feb 24, 2006 | 09:55 AM
  #91
93Polo's Avatar
Steve
Understood thats why I was asking if they were bringing an intake to market. It'd be nice to see both carb and a more OEM style intake offered. It is just a matter of time until everything starts hitting the market.
Thanks for the info guys.
Old Mar 6, 2006 | 11:26 AM
  #92
Cool_Hand_Luke's Avatar
Unless I missed it some where.
What is the RPM range of the 454 and what numbers if any has been posted from the dyno?
Old Mar 7, 2006 | 08:07 AM
  #93
Wet 1's Avatar
Question
Originally Posted by Ferocity02
I will order the heads as soon as I get more info on flow, valve size/material, springs, compatibility on LS1/6 blocks, etc...
World guys, can you shed some light on these questions?
I don't think you've flowed the heads yet, but what about the other stuff? Based on the price for these as cast heads and the size of the valves, I have to assume these heads will ship with the Ti intake valves and sodium filled exhaust valves... correct?
Old Mar 8, 2006 | 06:11 AM
  #94
Wet 1's Avatar
TTT for ?????
Old Mar 11, 2006 | 09:59 PM
  #95
World Tech's Avatar
LS1TECH Sponsor
Headswill be shipped as bare castings or assemblies with 5/16 stainlessvalves. Titanium would have to be ordered as option.
Old Mar 12, 2006 | 12:25 PM
  #96
racer7088's Avatar
Yes you can run a 4.500 crank with special cam and such and maybe people will make a 4.375 crank. Who knows. Eagle already was making 4.250s and you can get a custom crank even larger as long as you know what you are doing!
We are doing a 4.500 stroke at the school and it goes in pretty easy except for the camshaft clearance and that area but it's going together. I don't see that being any different of the tall deck world either and the cylinders are a little longer as well.
Old Mar 13, 2006 | 11:16 AM
  #97
Warhawk 1's Avatar
LS1TECH Sponsor
racer,
I am quite sure that the block you are using in your build is not one of our blocks, our casting differs from GM's casting. As well when most people ask if the block will accept a given component they mean bolt in not with additional machining. Given that you are at a school of automotive machining I am assuming you are making machining modifications in the block as well as re routing the outer oil galley line. am I correct?
B
Old Mar 15, 2006 | 06:24 PM
  #98
racer7088's Avatar
Thumbs up
Originally Posted by Warhawk 1
racer,
B
The galley is close! It all depends on how you do it! It will be in magazines soon!
Old Mar 16, 2006 | 12:09 PM
  #99
Big-DEN's Avatar
Eric,
Can these "extended deck" arrangements achieve strokes of greater than the 4.5" which is already tremendous?
What is max stroke that can be attained on stock 9.240" deck, 9.840" deck, 10.2" deck?
All of us would be interested in this factet.
Thank you,
Dennis
Old Mar 17, 2006 | 08:05 PM
  #100
Stang's Bane's Avatar
What About Compatibility Of The Heads With A Sleeved Ls1 Block? And Would A Ls1 Based Intake Work? If Yes You Will Have My Business!!!!!
