Warhawk Block?
Old Mar 17, 2006 | 08:21 PM
  #101
Ferocity02's Avatar
Originally Posted by Stang's Bane
What About Compatibility Of The Heads With A Sleeved Ls1 Block? And Would A Ls1 Based Intake Work? If Yes You Will Have My Business!!!!!
I believe that the LS7x heads will fit on LS1/6 blocks, sleeved ofcourse, which is what I plan on doing. An LS1 intake will not work with these heads, however, an LS7 intake is designed to bolt right up to these heads.
Old Mar 18, 2006 | 09:20 AM
  #102
Stang's Bane's Avatar
Thanks for the info. Is the LS7 intake available yet and if it is how much.????
Old Mar 18, 2006 | 01:56 PM
  #103
WARHAWK~572's Avatar
Part# 12569011
Old Mar 18, 2006 | 07:55 PM
  #104
Thanks Warhawk, I did some research and I found where to get the intake, but I just read a thread about t.b. issues now. I am still a good 9 months or so away from getting this baby finished, so I am sure everything will be ready to go by then. From everything I have read, you will definitely have my business.
Old Mar 19, 2006 | 06:36 AM
  #105
chuntington101's Avatar
anyone offering creat engines using these blocks yet?? if not anyone going to see how long they are going to be!
Chris.
Old Mar 23, 2006 | 08:46 PM
  #106
Dune-LS1's Avatar
Chris.
I'll have them. As a matter of fact, I'm using the Warhawk in "all" of my engine packages. Cost will vary but it will start around 20K and go up from there... <(Depending on options)
I'm not really selling to the asphalt guys, "yet" strictly dune folks... But I will share any engine scooby with you guys once these things start hitting the dyno... If anyone is interested....
PS: Mods you can delete my post if it goes against the advertisement rules... But I don't "think" it does... I didn't give out any company info.
Old Mar 24, 2006 | 06:57 AM
  #107
Dune could you PM me some more info on the engines you will be offering?? please!
chris.
Old Mar 29, 2006 | 02:20 PM
  #108
racer7088's Avatar
Thumbs up
Originally Posted by Big-DEN
Eric,
Can these "extended deck" arrangements achieve strokes of greater than the 4.5" which is already tremendous?
What is max stroke that can be attained on stock 9.240" deck, 9.840" deck, 10.2" deck?
All of us would be interested in this factet.
Thank you,
Dennis
Possibly 4.625 but the cam is starting to have to be made pretty small to clear and the oil galley might be extremely close and wouldn't go with many rods.
Old Mar 31, 2006 | 02:58 PM
  #109
Monty's Avatar
Eric,
Thank you,
Dennis
Is there a 10.2' deck version of the Warhawl LS7X block? I've had a 9.800" on order, but a 10.200" would be cool!
Old Mar 31, 2006 | 03:10 PM
  #110
Wet 1's Avatar
No, 9.840" it the tallest they are offering.
Old Mar 31, 2006 | 04:09 PM
  #111
Vertigo's Avatar
Could someone be kind enough to fill me in as to what is so special / different about this block? I mean basics b/c i don't really know much about this field...
For example is the block material stronger than iron? Will it be able to accept a longer stroke/bore than any other block would be able to thus far?
Old Mar 31, 2006 | 05:58 PM
  #112
bill mcdonald's Avatar
What about using this block/heads in different platforms, such as a gen 1 set up?
I read an article on the net that said the block had mounts for a gen 1 or LS style mount.
What about the bellhousing?
vertigo, read here.
http://www.gmhightechperformance.com/tech/0603htp_hawk/
Old Mar 31, 2006 | 06:03 PM
  #113
FunkyTownFBody's Avatar
The block is able to accept longer strokes than most ls-based engine blocks currently on the market.
Another great selling point is the fact that the cylinder walls aren't bored paper thin in between, and they also have provisions for two extra head bolts per cylinder (when used with Warhawk heads).
There's almost too much to list, if you really want a quality learning experience, complete with illustrations, check out the write up in Chevy Rumble this month.
This engine is still aluminum, but beefed up in all the right places.
Old Apr 1, 2006 | 10:07 AM
  #114
racer7088's Avatar
Thumbs up
Eric,
Thank you,
Dennis
The cylinder lengths are more of a limit than deck height. 4.250 can easily go in the 9.240 block but the cylinders are very short. All these newer blocks have a little longer cylinders as well.
Old Apr 1, 2006 | 10:50 AM
  #115
dhdenney's Avatar
Does anyone know what length rods should be used in these things?
Old Apr 1, 2006 | 11:26 PM
  #116
racer7088's Avatar
6.125, 6.200, 6.250, 6.300 etc. Not too many on center LS1 rods though in these size except 6.125 and a few 6.200s.
Old Apr 2, 2006 | 08:46 AM
  #117
OmniRex's Avatar
ls7 dry sump system bolt up?
Old Apr 2, 2006 | 09:58 AM
  #118
MerlinPro's Avatar
Collections Removal
OmniRex'
Warhawks are fully dry sump capable. Remember they are priority-main systems and depending on your usage, you might not need to spend for dry sump.
Old Apr 3, 2006 | 09:04 AM
  #119
Vertigo's Avatar
vertigo, read here.
Thankyou! This is almost scary!! At that price why would anybody go with something other than this block? From the sounds of it this almost sounds like an extremely reliable setup that will provide monster power! With those cubes do you think 550-600 rear would be easy with boltons and a med cam N/A?
Old Apr 4, 2006 | 06:16 AM
  #120
Warhawk 1's Avatar
LS1TECH Sponsor
Vertigo,
I believe those are attainable goals.
B
