Ls6-ls2-l92
Old Feb 14, 2006 | 03:17 PM
ifryrice's Avatar
Default Ls6-ls2-l92
Im stuck on which one to get. I plan on buying a bare block and honeing it and then buying a 4.00 Crank and Lunati pro mod connecting rods and custom pistons for Nitrous. What do yall think?
Old Feb 14, 2006 | 03:21 PM
See5's Avatar
No reason for a LS6 and only an LS2 if you can't wait. The L92 with it's heads should be the hot setup stroker.
Old Feb 14, 2006 | 04:52 PM
Wnts2Go10O's Avatar
right now id say ls2 stroker
Old Feb 15, 2006 | 08:49 AM
ifryrice's Avatar
ttt only 2 opinions?
Old Feb 17, 2006 | 12:57 AM
SuperSporttruck's Avatar
I want the L-92, so hopefully the block will come out soon. I may run LS7 heads and intake. should make some interesting numbers.
Old Feb 17, 2006 | 02:21 AM
67camaro's Avatar
L92!!!
Old Feb 22, 2006 | 10:33 AM
Pat7272's Avatar
If you were to build a ~402-412 inch LSx stroker with aftermarket heads, which block is the better starting point? LS2 or L92? Aftermarket heads, crank, rods, pistons ect, what difference will it make using the LS2 or L92 block? The L92 is not sleeved where the LS2 is right?
Old Feb 22, 2006 | 11:55 AM
slt200mph's Avatar
to the top
Old Feb 22, 2006 | 11:57 AM
NemeSS's Avatar
im goin 4.06 lq9 block with 4in eagle crank
l92 heads with carb and goin 2 have to wait for carb
manifold
but using msd controller for coils pac
414 ci with ported l92 heads carb 750 cfm hp
250ish cam 12:1 comp .625-.650 lift
for 85 fire bird with th400
