SDPC 402 Iron Block Special
Old Apr 20, 2006 | 12:54 PM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
Default SDPC 402 Iron Block Special
We have 3 iron block 402 short blocks in stock ready to ship. They have Eagle cranks, Callies H beam rods, Diamond -14cc dish pistons. These are LS1 based blocks so the valley and front covers from the LS1/LS6 engines will work with it. The special is for these 3 only at $3695.00 shipped. (lower 48 only). You can pm me with any questions or call 806-798-4000 ext 354.......
Old Apr 20, 2006 | 01:11 PM
bmfcamaro's Avatar
just out of curiousity what is the difference between the 408 iron and the 402 iron?
Old Apr 20, 2006 | 03:05 PM
bg-sdpc's Avatar
Bore size. The 402 is 4.00" bore and the 408 is 4.030"......
Brian
Old Apr 21, 2006 | 02:56 AM
SuperSporttruck's Avatar
Sorry, to get off topic but how much more is a 408 or 414, Thanks
Old Apr 21, 2006 | 03:17 AM
TheBlurLS1's Avatar
That's what she said...
These pistons work well with big cams? I'm looking to make over 500rwhp N/A.
I'm thinking with 59cc chambers, it would make around 11.14ish compression.
Old Apr 21, 2006 | 04:56 AM
Billiumss's Avatar
Good price, I need more money!
Old Apr 21, 2006 | 05:43 AM
LSs1Power's Avatar
Whats the compression going to be with stock LS1 heads? 9.6 C/R? Would the internal parts handle 15psi from a D-1SC + 100 shot of Nitrous?
Old Apr 21, 2006 | 03:34 PM
bg-sdpc's Avatar
We only offer them in standard 4" bore.
Brian
Old Apr 21, 2006 | 04:01 PM
bg-sdpc's Avatar
They will work fine with a big cam. The compression ratio with a 66cc head is about 10.2 to 1 so you would be at 11.4 with the 59cc heads & .051 gaskets.
Brian
Old Apr 21, 2006 | 04:21 PM
bg-sdpc's Avatar
10.2 to 1 with stock LS1 heads (66cc).
Yes it will work with 15psi boost + 100hp NOS but just once.
The pistons are not made out of the blown/nos material but they are still good up to about 150 shot of NOS so I would say they would work with the blower but no NOS.
Brian
Old Apr 22, 2006 | 09:56 AM
bluecamaroz28's Avatar
Crank, rods and pistons, are they forged? With LS1/LS6 ported heads, can it handle 300HP nitrous? Does it have the camshaft?
So, these are LS1 based not LS2, right? So, why posted under LS2 Forum.
Old Apr 22, 2006 | 10:26 AM
Josh@PremierAutosports's Avatar
Who makes 59cc heads?
Old Apr 22, 2006 | 12:15 PM
Spellbound's Avatar
I know Patriot used too....
Old Apr 24, 2006 | 06:14 PM
bg-sdpc's Avatar
It does have forged Diamond pistons. Cam and timing set not included. I would not go over 250hp NOS with these pistons. It is an LS1 based engine.
Brian
Old Apr 24, 2006 | 09:37 PM
Sent you a PM.
Old May 8, 2006 | 07:44 PM
Keith's Avatar
How much out of the hole do the pistons come out?
Old May 9, 2006 | 02:25 PM
Turbo04snake's Avatar
Is that a good deal?
Old May 9, 2006 | 10:08 PM
Blown04Z06's Avatar
IMO it is a good deal. considering the forged parts, pistons are designed for nitrous, these are capable of making 500/480 wheel with the right h/c and supporting mods.$400 more and you can get the LS2 aluminum block but you would need about $500 in other small parts to do the LS1-LS2 402ci conversion.
Old May 13, 2006 | 09:11 AM
bg-sdpc's Avatar
.007 out
Brian
Old May 13, 2006 | 09:13 AM
bg-sdpc's Avatar
Actually, for the extra $600.00 you can have the LS2 aluminum block and the parts required for the conversion.
Brian
