402LS2 Numbers
Old May 3, 2006 | 11:02 AM
  #41
niphilli's Avatar
Originally Posted by jjw3477
a company in florida did the port work but they are profiler 215 heads that like i said were opened up. If you want more info pm me but i will not disclose that info here.
Generally power is in the heads and the tune. Go with the AFR 225s or ETP or a good ported LS6...
Old May 3, 2006 | 11:17 AM
  #42
jjw3477's Avatar
already on it, i put my order in last week for a set of AFR 225's.
Old May 3, 2006 | 03:30 PM
  #43
mike c.'s Avatar
Wow,thats Low. I Did Near 460hp And 410 Tq, A 346ci Motor On A Mustang Dyno.
Old May 3, 2006 | 03:43 PM
  #44
jjw3477's Avatar
thanks for the boost of confidence i know its low im trying to figure out why.
Old May 4, 2006 | 02:15 PM
  #45
Dbluegoat's Avatar
Hey Jon
isnt this the 2nd set of heads w/ problems from them?
goodluck man....you'll get it all worked out eventually
Old May 4, 2006 | 03:06 PM
  #46
jjw3477's Avatar
Originally Posted by Dbluegoat
Hey Jon
Actually no my first set of heads i was using from them on just my head cam package was cool, i have had a pleathora of problems with these heads at the time i had no extra bank so had to roll with them I even had to send them back to profiler to get fixed for issues then come to find out the only rockers that could be run on these heads was Jesel J2K ($1,400) I thought about getting my money back on the heads since they were still unused at the time but he skated all around the issue and would not think of giving me my money back. But he sure as hell was quick to charge me. And what stings even worse was when i was running his first set of heads and they did pretty good i was his biggest backer, now i could give a **** less about him.
Old May 4, 2006 | 03:45 PM
  #47
Cool_Hand_Luke's Avatar
jjw3477 ,
Damn, I was going to put in an order for a LPE 403 late last year but held off. I was recently returning to the thought because I'm getting tired of the Warhawk wait.
I'm hoping Warhawk numbers can be put out soon with some good end results in reliability and tuning/build characteristics.
Old May 4, 2006 | 04:09 PM
  #48
jjw3477's Avatar
Originally Posted by Cool_Hand_Luke
jjw3477 ,
dont be thrown off by these numbers with the right heads and cam this package is sure to make into the 500's easy, just need a set of good flowing heads. Not bricks of aluminum.
Old May 5, 2006 | 01:20 AM
  #49
Blown04Z06's Avatar
jjw3477 ,
i seriously doubt this is a bottom end problem. LPE is solid when it comes to building their short blocks. this seems to be a head/cam problem. with that much lift shouldn't the duration be more in the 250-260 range?
ive got a LS2 403 sitting in my garage, not built by LPE but by someone else that is now working for a pro stock shop here in texas. he & the shop will be doing my cylinder heads, custom profile on the cam that is the most efficient based upon head flow and cubes. they will do the complete long block, install and tune too. in my conversations with him, he said heads, cam and intake make the power. LS short blocks have been machined, assembled, balanced and blue printed the same way for the last 7 years. cylinder head flow designs and cam profiles are what is constantly changing.
Old May 5, 2006 | 05:06 PM
  #50
Ed Curtis's Avatar
Cool
His pistons will not allow for a 11* valve angle head so it's AFR 225 heads or nothing!
Ed
Old May 7, 2006 | 03:32 PM
  #51
jjw3477's Avatar
Ed
at this point we are looking at making power by swaping out the heads, thanks to Ed, and the tune is still in question as to what direction to go.
Old May 8, 2006 | 07:10 AM
  #52
Mike Norris's Avatar
Jon,
Caught you for a short time Friday, but could not get free to see whats up. Before you get too far you need to see whats up with the oil pressure unless I missed something here that it is okay now. Also, if that one front oxygen sensor is reading 0 again and it is dumping fuel there is either something wrong in the harness or mechanically has a vacuum leak making her read lean on one side of the engine. Let me know.
Mike Norris
