Aircraft LSX revisited
Since the LS7 and L92 are out and parts will someday become available, I plan to use the block from one or the other and a combination of parts to achieve my goals, which are:
I need a fat powerband from 3200 to 4800 rpm. The engine will never see over 4800 due to propeller limitations. It will be geared using a chain drive of 2 to 1 ratio (widely used and proven to be reliable). The power loss through these drives is very low, less than 5% is a figure often used. I'd like over 350 max at 4800 and around 220-240 hp at 3400 rpm (sea level).
It will not have headers, only individual short stacks of around 12 inches long for two reasons: appearance, and the fact that there's no room inside the cowling for anything else. This also gets the heat overboard quickly. A good thing.
Firstly, does anyone have experience with engines running short stacks and if so, what cam specs minimize the power loss? I know ther'll be a loss, I'd just like to keep it small as possible.
I'm looking at using Megasquirt (dual) running in speed density mode.
I'm not sure whether to go with the new style (L92) heads or stay with the 6.0 vortec heads and intake. (I already have a LQ4 (new) longblock, intake, etc which I probably will end up selling unless I decide to use the heads and intake.) With the relatively low rpm, I'm not sure of any advantage to the L92 heads, and suspect the LS7 heads will be too big. Any thoughts?
The dry sump would be nice, with a custom oil tank to feed in unusual attitudes, but I haven't decided if it's worth it yet.
A number of LS1 based engines are flying, so there's no question they work. The operating profile is almost identical for a boat and an airplane. I'm just looking at thoughts on how to build an engine with the powerband I need with a displacement depending on which block I end up using.
Thanks for any ideas and thoughts.
ORG
You could probably use a resleeved Ls2 block to keep the light weight of thae aluminum block. The L92 heads would work fine I would think, but the probleme there is going to be an intake manifold. As far as I know, there is only the truck manifold for it. and the truck manifolds usually have some real height associated with them.
A stroker LS1 would be nice. Real fat midragne torque, which is exactly where you need it.
ls7 looks by far the best. i will be running takeoff rpm of 4500 max. i have not looked for a cam yet but it will require changing.
headers, especially long tube will produce more power than straight stacks due to scavaging. again you will require a diff cam for straight stacks. stay with efi to prevent icing.
vesta has a good dual ecm with simple mixture control and timing control. when comparing engines keep in mind gm uses sae rating rather than stp rating for hp. almost 5 % difference. ls7 is rated with stock exhaust manifolds installed, water pump turning, and remainer of accessories rotating but not under load. ls2 is also excellent engine with top torque at 4400 rpm.
Thanks
vesta sells computer seperate or anything seperate for that matter. jason is pretty good. also has a nice monitor system for ls engines. sells rads and prop
as well.
vesta also has a tight fitting intercooled supercharger package.
what kind of psru are you planning?
org
org
this is a 346 ls1 with a maggie on it
More Than Zero
Good luck with the build. Planes have a lot of considerations cars don't have to worry about, like changing altitude at 4000 ft/minute. On the other hand, you can take advantage of having to only really worry about a very small RPM band. I bet you'll get a lot of benefit from a well designed cam. Too bad about the exhaust, that could benefit from a fixed RPM too.
Is there a reason why you aren't using a higher RPM with a higher gear ratio?
Do you have room for a supercharger? All that cold air up there should allow a lot of boost at high altitude, as well as compensate some for pressure differences. If not, ram air should work nicely at 300 mph.
this would also hell with the presure diffrence and could be mounted behiund the engine so the profile wouldn't alter much!
thanks Chris.
What special considerations will you have to take into account with the oil in the oil pan? Some kind of uber dry-sump setup? With all that climbing and diving and rollings, oiling is going to be critical.
This sounds like an awesomely fun project...ive always wanted a P-51 myself
OPPS i jsut realized you want stock exhaust so the turbo might be out, LOL.
just a thought!
thanks chris
As for the pan, actually not a lot needs to be done, since all maneuvering can be kept to positive G...meaning the engine thinks it's upright no matter what the attitude really is. Bob Hoover used to demo a loop and roll with a glass of water sitting on the panel of his airplane and didn't spill a drop. Having said that, a dry sump would be very nice for the momentary changes in attitude involve n screwing up a maneuver, and the stock LS7 setup with a special tank is attractive in that respect. Most aircraft engines, however, don't have inverted capability either.
org
just a thought!
thanks chris
As for dumping the heat, there are really no problems except that this is a really tight cowling and will have minimal openings for air flow. Unlike the automotive engine bay, the radiator will be back under the belly and there' are big advantages (aerodynamic) to not allowing any more airflow through the cowling than necessary. The only planned opening will be the air inlet scoop for the induction and possibly an oil cooler (which will actually have a duct that doesn't allow air into the cowling, just through the cooler.) By dumping the heat overboard, all the electricals and lines will be lots happier. I figure quite a bit of the engine heat will be sucked out the openings for the stacks, too.
There are pictures of the installation of a LS1 on a similar airplane on my website (address above) along with pics of my airplane.
Thanks for the thoughts.
org
One of the nice things about EFI is the ability to compensate for the altitude changes. You still lose power with less air density, but the engine continues to run at peak efficiency. Another reason for using the computerized engine controls.
As for the rpm, I'm happier with the lower stresses on the engine at these speeds. I know the engine will last at higher rpm, but as long as I can get the performance I need without stressing it any more than necessary, I'll keep the rpm in this range. Another factor is that most reduction drives have been proven to work well at about that ratio. The reduction drives have proven to be the weak link in most conversions, so babying it is also a factor.
Do you have any thoughts on cam design for the short stacks? As noted, the operating range will be between 3000 and at most 4800 and all I need is the ability to accelerate from idle (probably 1200 rpm) into that range smoothly. Idle won't be really that important, within reason, since the engine will always have a load on it just to turn the prop, even at idle.
org
