Ported LS7 Flow numbers
Now that it's running the fun begins!!
Thanks for posting your progress. Have fun friend, you've earned it.
Richard
Update....the car is ALIVE! Started right up...
quiet valvetrain (aggresive cam), 50+ psi hot at idle, man am I happy.That is very little work for such impressive results. Congrats on your set-up. I look forward to some dyno numbers.
At the .600" lift point have more intake/head flow than ls6 ported heads without an intake.
Its going to be an interesting one to say te least, even with a moderate camshaft should do well. with a high lifting good duration, and all supporting cast we should see huge numbers.
4.100 bore flowed at true 28" vacuum.
intake
lift ported stock ported w ported intake
.100 77 69 n/a
.200 162 166 n/a
.300 259 245 259
.400 314 299 307
.500 352 340 326
.600 376 362 347
.650 386 360 356
.670 388 n/a 363
.700 392 360 367
exhaust (flowed reverse through kooks 1 7/8 header)
lift ported
.100 58
.200 121
.300 167
.400 208
.500 243
.600 252
.650 256
what was the intake runner volume before porting and after porting?
what about the exhaust runner also?
thanks.
We all can see that the ported LS7 intake to heads numbers are great,
what 327CFM@.5" with intake mani attached and 347@.6".
Most of the Fast90 combinations where 290CFM tops, even witha 350CFM head attached.
We never did see a dyno number.
Was wondering if you got a dyno number or track number out of this?
Dennis
I did dyno it, however it didn't make good power at all (in fact, very poor), so I'm not going to post them. I'm pretty certain I overcammed it and didn't have enough compression for it, its not making very good power at all. Very soft. I have a new cam in the mail. The torque curve looks great as far as shape, its just very soft. FWIW, my cranking compression was ~ 180-185.
I'll look for the flow numbers with the manifold.
What are you guys running for cams, on the LS7 heads? I would have bought an LG cam, but the guy I talked to didn't seem to understand any questions I was asking, and I'm not going to pay $440 for a cam when I can get one for $100 cheaper and I know what I'm getting that way.
Maybe look at the GMPP Grand-Am Cup cam as a reference 239/251 106 LSA ICL 47.
XE-R 236/248 110+2. I think that would put you in the ballpark.
Nate
I just noticed 455 cubic inches.
