Ported LS7 Flow numbers
Old Dec 3, 2006 | 06:06 PM
  #61
Greg Fell's Avatar
I redyno'ed with the 232/240 @ 110+2 and made 485 rwhp w around 480 rwtq.
Old Dec 3, 2006 | 11:43 PM
  #62
JakeFusion's Avatar
Super Hulk Smash
I don't recall if Greg is running the stock LS7 valves. I thought maybe he wasn't. If not, then the LSK will work, especially with those new Pacalloy beehive spings. Good harmonics.
Why not the LSK? I still prefer the XE-R, but it's hard to get the huge split without keeping the cam extremely mild on the intake side cuz of the 248 @ .050" limit. Even better are the EDC Hellion lobes.
Old Dec 3, 2006 | 11:59 PM
  #63
Chicago Crew UnderBoss's Avatar
MAN,
There are the perfect heads for the 482 cubic inch LSX mountain motor I want to build in about a year or so, and with some good agressive tuning and the perfectly selected matched cam 700rwhp should be a reality at 11:0 to 1 compression on 93 octane!! CAN you IMAGINE the TORQUE!!!
Old Dec 12, 2006 | 09:29 AM
  #64
gtovan's Avatar
These are my numbers I just got them yesterday. HPE did them. Left the runner diameter stock, worked elsewhere in the bowl.
Intake
.200/148 cfm .300/226 .400/300 .500/347 .600/ 383 .650/403
Exhaust (w/o pipe)
.200/132cfm .300/178 .400/220 .500/235 .600/243 .650/250
Will post my dyno results later.
Old Dec 12, 2006 | 10:22 AM
  #65
Big-DEN's Avatar
gtovan - those are ported LS7 heads? I mean what MORE can you ask for?
Gregfell - your numbers should be higher than this. Maybe your intake manifold was damaged in the porting work. An easy test is to swap a stock LS7 intake on there.
Also maybe a cyllinder is down or out due to sealing, fuel, spark or water, or something.
There is no reason you shouldnt be over the 600rwhp barrier.
Old Dec 12, 2006 | 12:35 PM
  #66
gtovan's Avatar
Yes, factory LS7 heads w/ Xceldyne Titanium intake valves.
Old Dec 12, 2006 | 12:47 PM
  #67
Bink's Avatar
. What RPM was the rwhp developed at???
gtovan:
Intake
Exhaust (w/o pipe)
Can't wait to see your dyno #s.
Old Dec 12, 2006 | 01:21 PM
  #68
Quickin's Avatar
Did you call Barry yet and chat with him? He just did 6 LS7 Vette's in Lauderdale and has 5 more sets sitting waiting, ported their heads and did a cam change. RWHP ranged from 556 to 586, with tiny cams in the 230's. He's porting the hell out of them.
Old Dec 12, 2006 | 08:42 PM
  #69
11 Bravo's Avatar
Anyone know if TEA has done any LS7's yet?
Old Dec 15, 2006 | 09:04 PM
  #70
429 Mustang's Avatar
I'm running a 246/257 112+2 cam motion grind.
Going to a 232/240 110+0 comp xe-r. The IC is 45* I believe.
That first cam just looks like a poor choice all around. I'm not sure what Cam Motion was going for there, but I'd be looking for my money back. Is it possible they sent you a solid roller profile? You don't mention the valvetrain, so I'm ASSuming it remains stock? What springs were you running with that cam?
Maybe we've all been spoiled by the LSx H/C successes of the past. Is it possible that 400 cfm (or rather the large accompanying port volume) is just too much for a "streetable" HR cam? I wonder if those heads would be right at home on a 7000 RPM SR motor with a MUCH tighter LSA.
Old Dec 16, 2006 | 12:34 AM
  #71
BlackHawk T/A's Avatar
gtovan:
Yeah, i'd like to see the RPMs, or even the curve differences in those two cams. It's really hard to compare with just numbers.
Old Dec 19, 2006 | 06:25 PM
  #72
Who is Barry and how do I get in touch with him?
My brother and I are researching a 427 LS7 block build and some of this info is alarming, to say the least. $175 truck heads are looking more like a bargain every day.
Just got off the phone with LG, and that conversation did nothing to ease the pain. $4000 gets me a cam, a set of springs locks and retainers, a set of valves, some minor (super secret) port work, head bolts, and gaskets. That's with me providing the bare LS7 heads. That's $6000 in round numbers to get 600 RWHP. The valves are supposedly necessary to ditch the lash caps, which become uncapped with this super secret cam. When I asked if they corrected the problem causing the valves to displace from the rockers, that was what the springs were for. Well, if the springs fixed the valve/rocker separation issue, why the need for different valves? My head is spinning.
We want to give someone a significant amount of money for the right combo,
but the greed and misinformation makes me pine for the blue oval again.
500 RWHP is a friggin' joke. We're 20 off that with a moderate effort 383.
Old Dec 19, 2006 | 08:08 PM
  #73
trumperZ06's Avatar
Something is WRONG !!!
A stock LS7 in a Z06 with air intake kit and headers is good for ~ 500 rwhp.
See some of Katech's info... not sure what's happening here.
Good Luck...
Old Dec 20, 2006 | 10:01 AM
  #74
Big-DEN's Avatar
somethine is wrong;
1. cyllinder out (fuel, spark, rings, preload, bent pushrod?, lifter, valve, gasket )
2. manifold broke due to porting ( hole, seal to head, internal leak, map sensor )
3. tune ( knock retard due to whatever, af between 12 and 13;1?, etc )
4. computer issues ( maf sensor used, tps?, map sensor?, vacuum? )
something is amiss.
Old Dec 21, 2006 | 01:46 AM
  #75
Louis's Avatar
Tom, there is a reason we do what we do. I dont spend the time and money to give everything away. 500 is not what we make, 600 is what we make. We make 480 on bolt on LS7s.
Im responding to that email.
Old Dec 21, 2006 | 11:00 AM
  #76
Louis
After reading my post again, let me say that I did not mean to imply that you guys were greedy. It was a huge mistake to put that statement in the same post where I quoted the price I was given by LG. The rant about greed and misinformation was WRT the wringer I've been run through over the last couple of weeks by all sorts of posers and pretenders. I did mean to stir the pot, but it was not directed at anyone in particular, and certainly not LG.
Tom
Old Dec 21, 2006 | 07:47 PM
  #77
Louis's Avatar
No problem, I came up and stuck my driver in yalls car at a moments notice at RA, I know you understand where I come from
Old Dec 22, 2006 | 07:34 PM
  #78
SStrokerAce's Avatar
Considering that LG's stuff makes over 600rwhp and they're not posting up 400+cfm flow numbers, and everyone else is and not getting close to that makes you wonder what everyone elses problem is? My thought is LG knows what to do and what not to do, so reguardless of the cost it works, either way it's a deal in the end since nobody else gets there from here. My guess is even though the cam specs are secret (which they should be) it's not just that.
3 LS1 cams at $450 a pop is a hell of a lot better than one set of custom intake valves????? That logic escapes me.
Bret
Old Dec 23, 2006 | 07:28 AM
  #79
Bret
All true.
I've already broken the news to my brother that cheap gets 550, but 600+ is gonna cost. $125 apiece for custom Ti intake valves being a large factor.
Since ours is a track only car, I've run the idea of solid rollers with stainless valves up the flagpole, waiting to see who salutes. Of course, the Jesel/T&D adds to the cost, but in the long run, this might be a better choice.
Old Dec 23, 2006 | 09:11 AM
  #80
gtovan's Avatar
Bret
For 600rwhp, they (LGM) are also using an electric wp, lightweight exedy clutch and forged pistons of an undisclosed c/r, no cats and a 3" catback, not exactly a head and cam package when you start swapping pistons.
600rwhp is no secret, a little head work, 12.25/12.5 SCR w/ forged pistons and a big cam to match the proper DCR and 7000rpm rev limit and you're there. Vette Doctors already got to 640 rwhp with this recipe albeit at 13/1 cr.
