Ported LS7 Flow numbers
Old Oct 27, 2006 | 11:19 PM
  #41
Nate_Taufer's Avatar
That cam should work a lot better. I bet cranking compression will be around 210 vs the 190 with the monster cam. Let us know how it does.
Nate
Old Oct 28, 2006 | 08:37 AM
  #42
Bink's Avatar
Originally Posted by Greg Fell
I'm running a 246/257 112+2 cam motion grind.
Would this have been a decent cam spec if the LCA (lsa) was tightened - to say 107 and installed +2 or 3?? Considering the cubes he has.
Old Oct 28, 2006 | 04:48 PM
  #43
With as efficient as the heads are I think it's too much duration by a good 8-10 degrees on both sides. Plus a 107+2 would make for extremely high DCR.
Nate
Old Oct 28, 2006 | 05:50 PM
  #44
GMW-CSL's Avatar
Default Love to see photos of intake and exhaust ports
Post some photos of the manifold, intake and exhaust, sides of the ported LS7 heads please.
Old Nov 11, 2006 | 01:48 PM
  #45
Greg Fell's Avatar
i redynoed with the new cam
old cam
cam motion 246/257 112+2 .669/.652
new cam
comp xe-r 232/240 110+2 .630/.644
cranking compression went from ~185-190 to 210
Old cam vs New cam Dyno Graph
it gained ~ 12 peak hp and ~ 40 ft lbs of torque...didn't carry it quite as far but thats fine.
the car is still very low, in my opinion, based on what others have done. wondering if the heads are just too radical for the ls7 manifold.
Old Nov 11, 2006 | 03:11 PM
  #46
gtovan's Avatar
What is your SCR and DCR w/ the new cam? If you could figure a way to get the cranking pressure up even higher (230-240/lb.) w/o closing your intake valve sooner than you are now, I think would show a good result. Glad to see the new cam took you in the right direction.
Old Nov 11, 2006 | 03:12 PM
  #47
Rollin Black's Avatar
old cam
new cam
Hello Greg.
Thanks for posting updates.
I am following your progress closely as I am also getting what I think are low dyno numbers for my similar set-up (LS7 top end on a 427 CI LS1 shortblock).
My first dyno session was 490rwhp/461rwtq SAE corrected.
Cam is a Comp Cam 229/237 .622/.636 113 LSA
What are you thoughts at this point to bring your power numbers up?
Thanks, Perry
Old Nov 11, 2006 | 09:09 PM
  #48
Greg Fell's Avatar
My SCR is ~11.3, and my DCR should be ~ 8.5 (up from 7.6).
Old Nov 11, 2006 | 09:12 PM
  #49
Greg Fell's Avatar
Originally Posted by Rollin Black
Hello Greg.
Thanks, Perry
At this point, I'm not sure what I'm going to do.
Was this a new motor, Perry? Or did you have this with an ls1/6 top end before?
Old Nov 11, 2006 | 10:28 PM
  #50
Richard@WCCH's Avatar
Thanks for the update Greg. I see the cam made some nice improvements throughout the useable rpm range. I'm a little in the dark about the mph instead of engine rpm. Any idea what rpm the torque and hp is peaking at?
Greg, is it possible to elaborate on exactly what was done to the head ports? Were the valve seats retouched? The reason I ask is because the flow at .500" lift is let's say "optomistic" by a bunch. I'm not saying the peak flow isn't correct, but I've never seen more flow at .500" against what the stock LS7 head can deliver. Not to mention the .055" smaller test bore used. Something doesn't seem right here...........
Richard
Old Nov 11, 2006 | 10:45 PM
  #51
Hello Greg.
The short block had about 1000 miles on it and previously had AFR 225 heads. Static compression ratio is 11.3:1
Perry
Old Nov 28, 2006 | 11:19 PM
  #52
GrannySShifting's Avatar
did any of you guys fiure out where the power is?
Old Nov 29, 2006 | 02:34 PM
  #53
LostCauseZ06's Avatar
OUCH.. i made more power with my 408 and patriot LS6 heads
hope you figure out whats going on with it.. those numbers seem very very low.
Old Nov 29, 2006 | 02:36 PM
  #54
btw.. dont think the manifold is restricting... your graph continues to climb. if you were maxing your manifold the power would level off alot more and alot sooner.. something doesnt seem right?
Old Nov 29, 2006 | 04:34 PM
  #55
Ratical's Avatar
I hope you guys figure out the issues you are having. I've been following along on some L92/LS7 head stroker buildups. So far I have seen all kinds of great flow numbers, but I have yet to see anyone posting and decent dyno/track numbers.
There are plenty of 402+ engines with ported ls1/6 heads or dart/afr heads putting down better numbers. Not bashing you guys combos at all here, just making a concerned observation because I researching a build on a 408/L92 combo myself. These results make me wonder if the huge intake port volumes on these new heads have killed their velocity and swirl.
Again, good luck getting the bugs worked out, and thanks for taking the chance and the hit to the checkbook on these new parts so hopefully the rest of us can learn from what you learn here.
Old Nov 29, 2006 | 04:35 PM
  #56
ive noticed the exact same thing...
Old Nov 29, 2006 | 08:25 PM
  #57
JakeFusion's Avatar
Super Hulk Smash
I think we just don't know what camshaft VEs work best with these new heads yet.
I'd opt for an even bigger split, Greg.
Comp LSK 235/251 110+2. Doesn't raise the IVC much, but pushes the EVO out a bit more, which is where the LS7 needs help. Anything like that might work though, i.e., a 227/243 110+2 for more torque or 247/265 108+2 for more power. Give the heads time to flow with the added lift and agressive curtain area of the LSK lobe.
LSK with those big, heavy valves might cause problems, however. Would need a helluva spring and some strong rockers/thick pushrods/heavy duty lifters.
Old Nov 30, 2006 | 10:27 PM
  #58
2c5s's Avatar
I just got my LS7 heads, the intake valves are 76 grams and the exhaust are 72 grams. Ain't nothing heavy about them.
Old Nov 30, 2006 | 11:17 PM
  #59
Big-DEN's Avatar
So the exhaust is 72G.
Those exhausts are 1.60 or 1.625"?
Intake is made of titanium so you can get the 2.25" titanium at nearly same weight as a 1.6x" exhaust valve in steel. Steel on the exhaust is better for heat.
What was the size of the intake valve on a 5.7L LT5? 1.85"?
What was the size of intake valve on a 4.6L ford 1.47"?
Old Dec 1, 2006 | 10:33 AM
  #60
Why is everyone so quick to throw LSK lobes on all cam lobes they can now? I dont think LSK lobes are ideal for every lobe intake and exhaust on every combo.... not by a long shot
