LS3 & L92 Info
Old Jun 7, 2007 | 12:35 PM
  #321
HSV-GTS-300's Avatar
Originally Posted by BADSZ28
Is that per head?
Is your google and your phone broken ?
Old Jun 7, 2007 | 12:40 PM
  #322
BADSZ28's Avatar
SDPC does not list them per head or as a pair. If you know, there is no need to be a smart *** about it. Also, SDPC is a sponsor here so it is OK to post links. Plus you can save us all the phone call.
Old Jun 9, 2007 | 05:56 PM
  #323
SS Blazer 07's Avatar
The heads are $175.00 each & it is best to go with all Manley valves & springs for the price. I have the bare heads & all Manley Pro-Flo cut stainless valves & they are sweet.
http://s85.photobucket.com/albums/k7...valveclose.jpg
http://s85.photobucket.com/albums/k7...ent=heads1.jpg
http://s85.photobucket.com/albums/k7...alvebottom.jpg
http://s85.photobucket.com/albums/k7...ent=valves.jpg
Notice in the pics how the valves are polished and the area in the ports is under-cut to flow about 20% more then stock. I have less then $1100.00 into them complete also good to about .620 lift. LOL
Old Jun 10, 2007 | 10:43 AM
  #324
GIGAPUNK's Avatar
I read somewhere that the bare heads are made from castings that don't flow quite as well as the casting being used in the assembeld heads. Does anyone have any info on this?
By the way, those valves look sick!
Old Jun 16, 2007 | 01:09 AM
  #325
sdteb's Avatar
Default lq9
will these cranks and heads work on a lq9 block?
Old Jun 16, 2007 | 02:35 AM
  #326
89Formulaws6's Avatar
you obviously haven't looked much.....
but yes
Old Jun 18, 2007 | 01:05 PM
  #327
04Yukonxl's Avatar
Yes, the bare heads are not finished like the assembled heads. You'll need to do clean up work and a good valve job on them to achieve the same results. And, as mentioned, the stock valves are a two piece design and should be replaced in a severe duty application.
Old Jun 22, 2007 | 05:08 PM
  #328
speeddemongto's Avatar
the L92 valves are strong right?
Old Jun 22, 2007 | 08:43 PM
  #329
how big of a cam can you run without flycutting?
Old Jul 11, 2007 | 09:48 AM
  #330
John Doe's Avatar
Is there a part number for heads complete?
Old Jul 11, 2007 | 04:37 PM
  #331
GIGAPUNK's Avatar
'04 yukon, can you define "clean up"?
Old Jul 11, 2007 | 04:47 PM
  #332
Mochanic's Avatar
12582713 for the complete assy. $413.50ea
If it were me, I would buy bare castings and an aftermarket valvetrain. (the stock valves are 2 piece)
I have researched the L92 and put into a nice spreadsheet that should help you guys out. Email me if you would like a copy. randy@attituderacing.com
Old Jul 12, 2007 | 09:24 AM
  #333
John Doe's Avatar
Thanks Man, email sent.
Old Jul 17, 2007 | 07:27 PM
  #334
INDIGO 5.3's Avatar
subscribing
Old Jul 22, 2007 | 06:40 PM
  #335
drain89's Avatar
subscribing
Old Jul 23, 2007 | 09:08 AM
  #336
Leadfoot1's Avatar
Is this a new trend that i'm not aware of....Letting people know when you subscribe to a thread???
Its not like we need this information,
Lead.
Old Jul 23, 2007 | 10:13 AM
  #337
MrDude_1's Avatar
Lead.
lol, its because alot of people have it set to automatically subscribe when you post in a thread.
rather then click the link to subscribe, (that is hard to see and alot of people dont know about) they just post in the thread, and its added automatically.
Old Jul 31, 2007 | 09:18 AM
  #338
$ho_tyme's Avatar
I also am interested in this. Mine have a nice valve job and everything has been machined. You can tell where they have been takin back apart as the outline from the spring cups are still visable.
Old Jul 31, 2007 | 09:11 PM
  #339
blue by you's Avatar
I didn't realize the stock valves were 2 piece. How is that possible and up to what power levels should they replaced with say, Manley valves?? How come the SDPC versions come with stock valves and are making excellent power with them?
Old Aug 5, 2007 | 05:15 PM
  #340
WizeAss's Avatar
statement is false..... I have a set of bare castings that where ported to flow over 365cfm..... all it took was some massaging by the right fella.
if I where buying them stock without plans of porting the finished heads are the only way to go!
