LS3 & L92 Info
From what I've personally seen, they are the 5364 castings. Don't know that there's any difference between casting number or not... but just sharing my information.
so he has a 95 camaro and awaiting to put an ls3 in it.
i was reading a little and saw that an ls3 and a l92 are kinda the same? Is it true that the ls3 also is from a truck? cuz thats what i was told but then i was reading and kept seeing that its from c6 vette... And whats an ls7?
I'm making enough power from my 243 ported, valve job, Manley valves Heads. with the rest of the typical bolt ons, and ported this and ported that, yada,yada,yada...
But with all the R & D that VA Speed, Richard from WCCH, and Kevin investing all the Time And Money into these heads have made me a true believer that GM Was / Is making a dynamite product that the average Joe can make great power on the cheap...
The more i get involve with my project I realize the full potential of the L92 heads right out of the box they are flowing enough to feed my habit, but there is always room for improvement.
Here are some results.
https://ls1tech.com/forums/street-ra...eo-inside.html
heres what i found:
NEW CASTINGS - .450 decks~!
I --- E
.300 - 229 - 174
.500 - 327 - 240
.650 - 370 - 257
.700 - 377 - 260
Im looking to bolt a set on my soon to be built 416 bottom end! This should be good for 650-680 N/A HP at the crank! Im stoked!
$950 is a deal for the PAIR!
Any advise?
heres what i found:
I --- E
.300 - 229 - 174
.500 - 327 - 240
.650 - 370 - 257
.700 - 377 - 260
Any advise?
They're local to me, certainly worth checking out as a replacement for my 243 heads.
The ports are not the same. LS-3 and L-92 heads are not the same ports as everyone thinks.
Theres more than just a difference in valves etc.
GM has changed the part numbers several times and along the way the porting changed. I think they may have dropped the L-92 ports now and only make the LS-3 ports now.
With 4 or 5 part number changes its hard to tell when this happened exactly.
