Has anyone put a ls7 cam in an ls1?
Old May 23, 2006 | 05:40 PM
5.3litre's Avatar
Default Has anyone put a ls7 cam in an ls1?
just like the title says
Old May 23, 2006 | 10:22 PM
5.3litre's Avatar
let me ask another question. is it even possible to put an ls7 cam in an ls1?
Old May 23, 2006 | 10:46 PM
TA BOY's Avatar
If Its The Same As The Ls2 No
Old May 24, 2006 | 12:29 PM
03 BUSA's Avatar
No because of the camshaft position sensor and cam wheel are located at different areas. The LS1 wheel is in the rear and the LS2/LS7 is up front. Will not work.
Old May 25, 2006 | 09:18 PM
PewterWSSicc's Avatar
You would think that GM woudl try and set these things up to all be interchangeable between LS type engines. For moddability and to save there buyers some money, so they will keep buying from them. I would if it was possible.
Old May 25, 2006 | 09:48 PM
UMIRacing's Avatar
You can use them as long as you change the front cover, cam sensor, extend the cam sensor wire and swap a and c on the connector. No to big of a deal.
Old May 25, 2006 | 11:05 PM
x phantom x's Avatar
STF veteran / 10 second club
Yup, and a sponsor or two sell a cable that extends the sensor wire and swaps the wires at the same time.. Nice and simple.
Old May 28, 2006 | 08:07 AM
magius231's Avatar
why would you want to go through all that though? There are so many different cams ground for the LS1 not to mention custom cams theres really no point in it...
Old May 28, 2006 | 11:00 AM
Spellbound's Avatar
A cheater cam is real close in spec's and you don't have to use 1.8x rockers IIRC.
