who built your ls2 402ci & how is it performong?
Old 06-08-2006, 03:30 PM
mike c.'s Avatar
Default who built your ls2 402ci & how is it performong?
i'm doing some research now because i'm going to make the ls2 402ci swap in a matter of months. i would like to know...
#1 who did you get your motor through?
#2 how is it running around town and at the strip?
#3 what crank,pistons and rods did you get?
#4 what heads,headers and cam if you don't mind telling the cam?
#5 what are the #'s (jet or stang dyno)
at this point i'm looking at the rapid motorsports ls2 402 long block.what do you think of this product?
i see some post saying ls2 402ci down on power,so i'm starting my reasearch now so it dont happen to me.i know it's alot of questions but anyone who will take the time to help,THANKS ALOT.
mike c.
Old 06-08-2006, 04:11 PM
DrkPhx's Avatar
SDPC shortblock, I assembled and installed the longblock.
Runs great around town, no track times yet.
Diamond pistons, Crower rods and Eagle crank.
AFR 225's, QTP 1-7/8" and 3" Y, Rapid 244/250 cam.
No dyno numbers yet.
Rapid builds killer 402's that are proven to put down big numbers.
Old 06-09-2006, 09:32 PM
mike c.'s Avatar
thanks alot,anyone else? PLEASE.
Old 06-09-2006, 10:35 PM
gman's Avatar
#1 SDPC
#2 Runs Great around town, no track times yet
#3 eagle crank, diamond pistons, crower rods
#4 Afr 205's, Kooks 1 3/4" and 3" y with cats, tsp ms3 cam, Fast 90/90
#5 On a dyno jet I made 471rwhp 440 rwtq through a locked a4 at 10.9.1 compression
I feel with bigger cam and some induction work I should beable to get real close to 500 rwhp.
Old 06-10-2006, 03:42 AM
rambo benson's Avatar
Gman may I askwhat are the approx. specs on your cam?
Hey I am really interesed to know if someone dynos both with and without FASt 90/90 too!
Old 06-10-2006, 06:33 AM
wheeelzzz's Avatar
Check out this vid i found.
Now thats some power.
http://www.thevettedoctors.com/video...rls2-steve.wmv
Old 06-10-2006, 07:42 AM
gman's Avatar
Ms3 237/242 .603"/.609" 113 lsa
Old 06-10-2006, 09:45 PM
mike c.'s Avatar
565hp & 506tq from vett doctors . i need to find out more about that set up.
GMAN-how do the afr 205's feel on that 402? most use the 225 heads,what made you go with 205's?
Old 06-11-2006, 09:12 AM
gman's Avatar
Basically this is the same set up I had on my stock bottom end ls1 before I blew the motor. The heads have been milled to 61cc and work good on the motor. Where my set up lacks is in the cam and in the induction. The 75mm lid and maf need to be upgraded to 85mm and my intake needs to be ported. I actually gained 10hp on the dyno just by descreening the maf. Once I upgrade these last few parts I am hoping for 500 rwhp.
Old 06-11-2006, 10:27 AM
Z06kern's Avatar
1. W2W Shortblock, I assembled and installed complete motor.
2. On the street the car runs great, 10.69 @ 133 1.60 60' 100 Shot at the track. Should be low 10's with a better 60'.
3. Mahle Pistons, Callies Crank, Callies Compstar Rods
4. TSP/Patroit Hand Finished 59cc LS6 Style Heads, Kooks 1 7/8 Headers, TSP Texas Giant Cam 248/254 .622/.614
5. First dyno was 485RWHP/440RWTQ, but I have worked on the tuning at the strip and have ran consisantly in the 10's. Probally around 510/480 range NA.
Old 06-11-2006, 04:06 PM
8 second mod
Noyzee's Avatar
Wink
EAST SIDE PERFORMANCE!!
MORE OF A STRIP GUY, BUT SO FAR SO GOOD ON BOTH ENDS
EAGLE,DIMOND CUSTOMS,LUNATI
AFR, KOOKS, ESP N2O CAM
DYNO MEANS NOTHING, BUT I JUST WENT 9.3 @ 144 FIRST PASSES ON THE CAR TODAY! 250 WORTH OF SPRAY
mike c.
HOPE THAT HELPS. GOOD LUCK!
Old 06-11-2006, 08:34 PM
TopFlite's Avatar
I bet all your friends are jelous. Which head gaskets did you end up going with?
Old 06-12-2006, 01:02 PM
Z06kern's Avatar
GM mls gaskets.
Old 06-17-2006, 12:06 AM
mike c.'s Avatar
thanks...i've talked to mike at rapid and at this point i'm looking at their 402 long block. unless there is something better out there that is the one i'll get.
thanks, mike c.
Old 06-18-2006, 12:10 PM
NEVRLIFT's Avatar
I'll answer for my friend who doesn't post on here.
SDPC shortblock, MTI Racing assembled it.
Runs awesome especially with the 3.90s out back..
Mahle pistons, Compstar rods and Callies crank.
Stage 3 LS6s, SW 1 3/4" headers, MTI custom cam(~240/245)
Dynojet: 480rwhp/467rwtq
Old 06-18-2006, 03:31 PM
mike c.'s Avatar
would anyone trust the eagle crank in the 402 block? some say eagle is JUNK and some say it's just fine. any in put????????
Old 06-19-2006, 07:09 AM
8 second mod
Noyzee's Avatar
im running eagle, and a few of are other 8 and 9 second cars are also. cracks are 4340, there are only a few company's that make cranks, then places like eagle, lunati ect puts some small touches on them, and throws there name on them, so with a decent name callies, eagle lunati ect you cant go wrong.
Old 06-19-2006, 07:22 AM
electric_ta's Avatar
Default new 402 questions
i am putting a 402 in my 98 ta and got a couple questions just wondering how and what you did with the knock sensors n also what one you think would better high compression or low compression for a dual stage 250 shot on a 402.
thanks
Old 06-19-2006, 07:30 AM
8 second mod
Noyzee's Avatar
thanks
i run no knock sensors, and im around 12-1 cr with my setup.
Old 06-19-2006, 08:36 AM
Cyborg's Avatar
#1 who did you get your motor through? SDPC
#2 how is it running around town and at the strip? Great
#3 what crank,pistons and rods did you get? Eagle, Diamond, don't remember
#4 what heads,headers and cam if you don't mind telling the cam? AFR, Kooks, 232/238 115
#5 what are the #'s (jet or stang dyno) 621RWHP/571RWTQ SAE daily driver tune, pump gas
Good luck!
