Dyno Results: SAM's 500" ERL Sleeved LS2 (Over 700 hp on 93 Oct) *Dyno Graphs Inside*
#42
I think you find the graph of this motor has very wide torque band.
It is not a peaky HP motor.
I am sure if this is a wet sump or dry sump.
The LG motor was a Dry Sump.
Also I would not compare power made at 6,100 rpm's to 7,000.
Throw a .680-.700 solid roller in this....
#44
Brandon
#47
About the only large group of ls7 dynographs I found were on LG's site. They posted around 6 LS7 graphs with header/cam swaps. All were making in the 540-550 whp range except the "625whp" one. I googled that further and apparently "exhaust port work, electric water pump, and some special LG touches" made up the additional 75whp. I guess drysumping could be considered a special touch, but I didn't see that additional "feature" posted anywhere I looked. Where did you see that? The other two items add up to about 15whp at the most. Nice to see that LG 1 3/4 headers will support that power though!
#49
It's always the average HP and torque that gets the job done, since no trans. can keep the motor at peak #'s. The engine masters challenge always uses averages to compare engines.
This is a wet sump, pump gas street motor. Hats off to everyone at S.A.M. to show a real life street build before going race fuel, 15:1, solid roller.......
#52
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by chuntington101
do you think this motor could push past 800bhp with a little more compresion and a wilider cam???
Chris.
Chris.
I will answer you with this "
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Graph will be up in a few days. I have been gone on vacation and will not be back in for a few more days. Sorry for the delay and take care guys.
Gray Arrington
www.SAMracing.com
#54
Gary i ment to add, on pump fuel, sorry
Chris.
Chris.
I am finally back in the office, so the Naturally Aspirated and Nitrous graphs WILL be posted today.
Regards,
Gray Arrington
www.SAMracing.com
#57
Crazy cool
. Think the intake manifold will be cooler since it will be lifted off the motor?? ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Make mine a 471" with the 4.200" bore and 4.25" crank and a 250°/260° cam with say .625"/.640" and 110° LSA
![Icon Cool](https://ls1tech.com/forums/images/smilies2/icon_cool.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#58
Originally Posted by 1CAMWNDR
Crazy cool
You can give ERL a call and they can hook you up
#60
Doing some quick math. The avg. NA torque between 4100 - 6400 is 625 ft/lbs. and the HP is 624. That's definetly a wide powerband and I don't think anyone would notice if you missed a shift point. The 703 peak Hp was still creaping up at 6400. That would have put you in the top 5 against the fully built 509" big blocks in the 2005 engine challenge even with a stock intake, etc.. Most of those motors have little to no oil pressure and are on the verge of detonating to make it through a few dyno pulls. I would say your first baby step was pretty good.
