Katech "Value 427" short blocks
Old Oct 27, 2006 | 09:16 PM
  #101
z-ya's Avatar
I haven't been able to sleep since this thead appeared,thanks Jason.
Old Nov 10, 2006 | 01:33 AM
  #102
JGA's Avatar
JGA
Hi
Nice motor. Sorry I am new to re-sleeving blocks. Just woundering how it works. It appears all the material between the bores have been removed. Is the strength of the block affected? Are Darton mid sleeves an option?
Thanks JA
Old Nov 10, 2006 | 08:35 AM
  #103
Katech_Jason's Avatar
LS1TECH Sponsor
Originally Posted by JGA
Hi
Thanks JA
In short, the old sleeve is machined out as well as aluminum behind the sleeve. The sleeves have a lip at the top so although they are touching at the top, there is parent material behind the sleeve further down. We have had zero failures of our sleeved blocks and we are comfortable with the strength to at least 1000hp. We do not use Darton MID sleeves. Not that there's anything wrong with them, we just prefer a dry sleeve that is custom made for us to our specification.
Old Nov 10, 2006 | 02:54 PM
  #104
Bink's Avatar
Jason - what's your current build time on a value shortblock?? TIA.
joel
Old Nov 10, 2006 | 03:22 PM
  #105
LS1TECH Sponsor
joel
About as long as it takes me to go upstairs, get one and put it in a box.
Old Nov 10, 2006 | 03:42 PM
  #106
Wnts2Go10O's Avatar
you with a fork lift...may god have mercy on us...
good stuff
Old Nov 10, 2006 | 03:50 PM
  #107
LS1TECH Sponsor
good stuff
I think I'll just use the elevator.
Old Nov 10, 2006 | 04:11 PM
  #108
Bink's Avatar
Cool, but I want a few changes.
Katech "Value 427" short block with Katech forged LS7 pistons, hardcoat anodized..................................$7230
Billet main Caps.........................$1000.
*********************Total $8230
With a Forged 3.62 Crank (+ $1000?), and the above upgrades, what's the build time and cost?
Old Nov 10, 2006 | 04:14 PM
  #109
LS1TECH Sponsor
If you just want the short block, 1 week...If that.
Old Nov 10, 2006 | 10:59 PM
  #110
Bink's Avatar
Thanks Jason. I'll call you.
Old Nov 14, 2006 | 10:09 PM
  #111
Bink's Avatar
Bump^^^^^
Old Nov 17, 2006 | 10:12 PM
  #112
JB2wheeler's Avatar
Default Stupid newbie question
Could you use the value 427 block with the 9 to 1 ratio to make an engine for a race car tow vehicle/daily driver and use cheap heads like on a 2005 GTO engine or a LQ9? Would not the iron block from the LQ9 be better for making big cube blocks than the aluminum block? 65 pounds would not be that much extra weight if the iron block was better. JB
Old Nov 17, 2006 | 10:22 PM
  #113
LS1TECH Sponsor
You can use any 15 degree LSx head up to 2.100 intake valve diameter. I don't know why you would want to go that low on compression NA. Our sleeved LS2 works well and we've had zero failures. I see no need for the iron block.
Old Nov 18, 2006 | 06:05 PM
  #114
JB2wheeler's Avatar
Default Low Compression
The reason I stated the low compression was, if I came into some money later on I could always have the foundation and I could update the top end. I figure that would be better than getting a cheaper block with better heads and then updating the block later on when I was ready for boost. JB
Old Nov 25, 2006 | 09:58 AM
  #115
TrekGTO's Avatar
What about for LS2 GTO the 24x vs 58x Reluctor Wheel? Can that be changed or does that mean different crank? I was thinking your short block and all stock parts from LS2 for 05 GTO 6sp. Maybe Cam Kit oil pump LS7 Timing Chain but use as much as I can from stock LS2 7K Mi.. Does this make any sense? What would it take to make work? I can do upgrades later. I know there are cheaper upgrades I just want 7ltr!
Old Nov 25, 2006 | 11:01 AM
  #116
LS1TECH Sponsor
Yea, that makes sense. You could do the upgrades later. Yes, we can build with the 58x crank trigger.
Old Nov 26, 2006 | 09:18 AM
  #117
TrekGTO's Avatar
I think I’m gna order 1 of Katech 427 short block he says all I would need is Bolt and Gasket set and part out my LS2. I wonder how it would run with stock LS2 parts; I’m thinking small cam kit but just want good running driver. He says there blocks are better than stock LS7 used in other example no failures and they seem to have a top notch facility and rep. I know there are cheaper mods just want to start with 427 and do mods later if I want, could do 402 with stroker kit but just not same to me. Any one know about 58x crank trigger I have read that it started in 05 and 06 both. Any one know for sure I’m thinking all LS2.
Old Nov 26, 2006 | 01:04 PM
  #118
LS1TECH Sponsor
Sounds good. You should have a torque monster for the time being until you get some heads. I've got a good cam for you also. 58x started in 06. Since you have the engine out of that GTO you should pull the crank sensor off and look in the hole. Check to see if there are small teeth (58x) or Large (24x).
Old Dec 16, 2006 | 09:27 AM
  #119
TrekGTO's Avatar
Is Katech "Value 427" short block balanced? If not how much $
Old Dec 16, 2006 | 10:37 AM
  #120
LS1TECH Sponsor
Yes, everything we build is balanced.
