need valve springs help
Old Sep 4, 2006 | 07:36 PM
StreetnStrip's Avatar
Closed ex-Sponsor Account
Default need valve springs help
I wanna run a cam that has 670 lift. I wanna run the new l92 heads which have the 2.16 intake valves in them. Does anyone know what valve spring I can run with this cam?
Old Sep 5, 2006 | 09:16 AM
SStrokerAce's Avatar
Why do you need .670" lift with a 2.160" valve? You don't need as much raw lift with more valve size.
Two other things, the valve length will probably need to be increased to get something that can handle that lift in there since the coil bind would have to be extremely low to get it there.
You need to have these heads in your hands and measure everything to figure all of this stuff out.
Bret
Old Sep 5, 2006 | 10:40 AM
Bret
I got the cam for a $100.00 and if u look at the l92 heads they still produce power in the 650 range.
Old Sep 5, 2006 | 12:43 PM
Yeah, I understand they still flow well over .600" of lift. The problem being how to get valves that are long enough AND most applications will not need more than .600" lift....
Sounds like you are just trying to do everything cheaply, which on new untested stuff is not going to work out well. A LS cam is just not going to work well with a L92 because it's probably way off the normal.
Bret
Old Sep 5, 2006 | 12:45 PM
Bret
trust me Im not tryin to be cheap Im just wanted to try it out amd see what happens.
Old Sep 5, 2006 | 12:51 PM
Ok, because getting that setup to even work on the heads is going to take a lot of money.
Bret
Old Sep 5, 2006 | 02:07 PM
Bret
how do u figure?
Old Sep 5, 2006 | 09:56 PM
Longer custom valves, buying and trying multiple springs that "should" do the job (but you will not know till it runs), the area of the spring seat locator and maximum diameter you can put in there.... etc... it's not just a bolt together deal. Top that off with a cam that's not going to perform well with it and I just don't get it.
Bret
