Crate LS7
Old Oct 10, 2006 | 04:40 AM
duke of cruel's Avatar
Default Crate LS7
Hi guys,
how many of you has bought an crate ls7, and how well are they holding up?
It is not z06 vettes but crate engines.
DoC
Old Oct 10, 2006 | 07:20 AM
Bink's Avatar
Originally Posted by duke of cruel
Hi guys,
DoC
Old Oct 10, 2006 | 01:57 PM
John B's Avatar
Moderator
I've have mine running for 7 months as a daily driver with zero issues. I have dynoed it and raced it at the track without any issues....my experience has been 100% positive! I'm just beginning the modifications to it now.
Old Oct 10, 2006 | 04:18 PM
98blackSS's Avatar
So far, so good.. Just wrapped up SD tuning using the LS1 PCM..
Old Oct 10, 2006 | 07:34 PM
KOOL C5's Avatar
I just had a LS7 installed in my 97 C5. The engine is stock with 2 inch Headers. I want to do some more tuning and could use some help, but I have to find out why it keeps going into reduce power(1516) first. I'm going to try an upgraded TAC Module tomorrow. 98blackSS, did you use the LS7 TB and did you have any 1516 problems? Thanks for any help.
Tom Hall
Old Oct 10, 2006 | 08:16 PM
98blackSS's Avatar
Tom Hall
Yes, we're using the stock LS7/(LS2) TB. No problems with P1516 though. Just the expected P1514 code. Just needed to increase the table values for TPS Sensor Calc airflow (In HPt, Engine Diagnostics-General-TPS sensor-Calculated airflow vs. TPS vs. RPM). I just did a quick 50% increase on all values to avoid triggering REP.
Are you using the OEM PCM? What tuning software?
Old Oct 10, 2006 | 08:31 PM
KOOL C5's Avatar
Yes I'm using the OEM PCM and LS1 Edit. I'm geting the 1516 after it warms up and idles for several minutes and also when slowing down at a stop light at times. Runs great if you don't go slow
Tom
Old Oct 10, 2006 | 08:41 PM
98blackSS's Avatar
Tom
That's when I saw it as well, but diff code. Check the pins & harness as per:
https://ls1tech.com/forums/pcm-diagnostics-tuning/519619-tb-issues.html
also
http://www.gearchatter.com/viewtopic9440.php
Old Oct 11, 2006 | 02:42 PM
KOOL C5's Avatar
https://ls1tech.com/forums/showthread.php?t=519619
also
We did the pin swap before we could even start the car.
I'm going to swap the TAC Module now and will report back, thanks.
Old Oct 11, 2006 | 03:14 PM
98blackSS's Avatar
Good luck, let me know how it goes..
Old Oct 11, 2006 | 04:40 PM
KOOL C5's Avatar
No luck on the new Tac Module. I'm going to check the wires again.
Old Oct 11, 2006 | 05:25 PM
98blackSS's Avatar
Looks like it's basically checking commanded vs. actual blade position.
Perhaps setup your scanner to log ETC desired position vs ETC actual(TPS)? Shouldn't even need to start the car. Pull your intake hose off and have someone watch the TB blade. Make sure it operates smoothly from closed to full open while someone operates the pedal.
Old Oct 12, 2006 | 07:00 PM
KOOL C5's Avatar
I took the TB off and found the blade was hanging just a little bit. Filed the blade a little and smoothed it up, problem fixed. I hope the engine is a little bit better quality than the TB. Thanks for the help.
Tom.
Old Oct 13, 2006 | 09:51 PM
b005td's Avatar
where do u guys get the crate engone from ?
i m thinking about doing it on my rx7
i wanna get one with the best price !!!
Old Oct 13, 2006 | 10:29 PM
98blackSS's Avatar
went through Fred Beans - $12,5k
98blackSS's Avatar
Tom.
No problem, Tom.. Glad you got it worked out!
Old Oct 14, 2006 | 01:48 AM
GMW-CSL's Avatar
Default LS7 crate good price?
Contact Shaun Carter valvegod@aol.com
Old Oct 14, 2006 | 05:13 AM
KOOL C5's Avatar
That's were I got mine, Shaun is good guy to deal with and he can change the Reluctor and Cam gear if needed.
Old Oct 14, 2006 | 06:13 PM
c5racr1's Avatar
got mine from jegs< 2004 CTSV runs great
Old Oct 14, 2006 | 07:15 PM
98blackSS's Avatar
Couldn't agree more.. Shaun is a great guy. Met him at the LS7 plant tour in Wixom this past summer. We buy all sorts of odds and ends from him for our projects
