who is making 500 rwhp with a ls2 402???
8 second mod
and how are you doing it?
my buddy is building a 402 for his street 02 z06. he is looking for pump gas 500 rwhp streetable.
i say it can be done with eas with the right parts
I'll have to take mine to the dyno and see what I'm putting down.
I'm going to the track this weekend with M/T d/r's to see what it'll do.
Shooting for 11.30's, car weighs around 4,000 lbs with me in it.
I can pretty much figure out the hp after I make some good passes with good drag radials. Best so far on Nitto's was 11.55 @ 119 but I had to pull alot of timing out of to get it to hook up off the line.
How about 507 RWHP with just a LS2?
https://ls1tech.com/forums/dynamometer-results-comparisons/597079-507-442-stock-bottom-ls2-c6.html
We just finished a GTO that made 453rwhp on our Mustang dyno through IRS. It also had a pretty mild cam. I would think 500rwhp on a Dynojet would be relatively easy to achieve. This was using "out of the box" Dart heads.
500hp should be easy. i made 463hp 414tq w/a 346ci on a mustang dyno pump gas 11.0.1 comp. i'm doing a new build up either a 402ci w/AFR225 head,s tsp giant cam and a fast 90 intake. i would like to make 510-520ish hp on the same stang dyno. i'm also looking into the l92 418ci from tsp aswell.
Originally Posted by Brian Tooley
Originally Posted by verbs
he said on pump gas, that car has 12:1 compression
AFR 225 or TFS 225 heads
238/244 or 242/248 Cam
FAST 90mm setup
36-42lb injectors
Kook 1 7/8 headers
Consistant 495-540rwhp/ 475-505tq.
The midrange and drivability is awesome.We've done alot of Vette's with this setup.
Slowhawk (or anyone for that matter), how do these end up sounding and driving? I don't want some beast that is hard to daily drive. Those cams look big, but do you guys get them to be manageable for a daily driver?
-Geoff
-Geoff
i have a 402 with a 250/258 .580 .580 108 lsa. With cnc ported ls6 heads, with a 90 setup with 42 lb inj. I havent dyno it yet, but i think i need to get some differ heads, i have 10.9.1 compression, but it dont like nothing but 93. the heads flow around 320cfm. but i dont think its enough, what do u all think?
