Pictures of the GMPP LSX Block
This part concerns me, doesn't a LS1 have a 24x. Isn't it crank dependant? A LS1 Eagle 4.100 crank should work fine, correct?
Where will we be able to get head gaskets from, GMPP?
Cometic will make head gaskets for the LSX.
Robin
The question is...will the SBC now become the next Ford Flat head?
Bill
Bill
Sucks that the LS7X World heads won't bolt up to that block...
Is GM calling this a Bowtie block?
ADMIN
If you want to use the GM electronics you will need to use a LS2 style front cam sensor.
There are a ton of threads about converting to the LS2 style sensors.
Robin
Robin
So there are no provisions in the valley area for knock sensors like a stock LS1 has?
Any chance you or someone else could post some more pics of this block at different angles and higher res?
What head bolts will we be able to use, standard LS1 ARP kit?
If the bore spacing is the same as a regular LS1, how is this block that much different than a stock LQ9 iron block? Why wouldn't we be able to bore out a LQ9 block the same as this new GMPP LSx block (up to 4.250)? Please explain and be technical.
Bill
