Any negatives on Hooker's on 427
Old Oct 30, 2006 | 07:07 PM
03 BUSA's Avatar
Default Any negatives on Hooker's on 427
Due to budget issues I need to know if the Kooks are really worth the extra money over the Hookers. I am building 427 LS2 w Fast 90/90 set up and very healthy cam. Thanks for the input.
Hookers Coated: $820
Kooks uncoated: $1097
Old Oct 30, 2006 | 07:16 PM
LPE SS's Avatar
You're building a 427 and thinking about short cutting headers over a few hundred bucks? Do the Kooks.
Old Oct 30, 2006 | 10:41 PM
Black Sunshine/ 00SS's Avatar
Eldebrocks, stainless steel just released, should be around $600, and has a true race merge collector.
Old Oct 30, 2006 | 10:55 PM
Beast96Z's Avatar
I was gunna say go with the Edelbrocks as well. They will give you a stepped design over the Hookers, and should be equaly priced, coated. The Kooks are stainless, so there is no need for coating. If the Edelbrocks come in stainless, that would be nice.
Old Oct 31, 2006 | 05:28 AM
EPP's Avatar
EPP
Smile
Give me a call at 260 244-4808 for a great price on Kook's headers, much less than the price above. Bob
Old Oct 31, 2006 | 06:41 AM
Bandit28's Avatar
Why are the Kooks so great?
Old Oct 31, 2006 | 08:07 AM
http://www.edelbrock.com/automotive_...petition.shtml
1 3/4 stepped to 1 7/8, with a 3 1/2" race merge collector.
Old Oct 31, 2006 | 09:12 AM
ONEBADWS6's Avatar
I switched my Hookers for stepped Kooks and gained no E.T improvement.
Old Oct 31, 2006 | 04:59 PM
03 BUSA's Avatar
I was told not to go with a stepped setup. What is the advantages?
Old Oct 31, 2006 | 05:55 PM
Beast96Z's Avatar
When talking with Kooks a long time ago, they reccomended not going to the stepped on a stock bottom end motor unless you were spraying 200+ or had alot of forced induction. However, they would be a great 400-427 ci header.
It provides a scavenging effect that helps pull exaust from the port instead of being pushed by the motor. However, you need enough motor to be able to use the size header in question. For a stock bottom end, 1 5/8 stepped to 1 3/4 would be much better, but no one makes it.
Old Oct 31, 2006 | 07:10 PM
03 BUSA's Avatar
It provides a scavenging effect that helps pull exaust from the port instead of being pushed by the motor. However, you need enough motor to be able to use the size header in question. For a stock bottom end, 1 5/8 stepped to 1 3/4 would be much better, but no one makes it.[/QUOTE]
I am going with a LS2 427, would you recommend the stepped header?
Old Nov 1, 2006 | 12:25 PM
ONEBADWS6's Avatar
[QUOTE=Beast96Z]When talking with Kooks a long time ago, they reccomended not going to the stepped on a stock bottom end motor unless you were spraying 200+ or had alot of forced induction. However, they would be a great 400-427 ci header.
Look at my sig, does it look like I'm running a stock bottom end?
Old Nov 1, 2006 | 01:05 PM
gun5l1ng3r's Avatar
Your sig says nothing...
Old Nov 1, 2006 | 02:07 PM
ONEBADWS6's Avatar
99 WS6, moser 12 bolt, vic jr intake, custom hyd cam, High Flow Heads LS6 castings, TH400 with ATI converter. All it has is GM junk in it!
Fastest and quickest LS2 N/A 9.82@137
How is that nothing? You can't posibly think that was done with a stock short? Oh wel carry on, just telling of my experiance.
