Details of the electronic throttle (wiring, internals)
Old Nov 9, 2006 | 12:57 AM
280Z28's Avatar
Default Details of the electronic throttle (wiring, internals)
I'm looking for some specifics on the 90mm drive by wire throttle body.
The connector has 6 pins labeled A-F.
A, B have to be the driver input (1 ground, 1 servo pulse).
I can't tell yet for the other 4. I need a better way of clipping my meter on these leads. If no one knows, I'll grab some tiny spade connectors tomorrow and try again. C-F are all connected (1.4k-4.21k between any two pins in this group, varies by which pair of course).
Pending questions:
1) What's the polarity of the drive pins A,B
2) What's the servo pulse frequency (I can test this if I find someone with a gto or vette)
3) What exactly are the pins C-F?
Old Nov 9, 2006 | 06:19 AM
See5's Avatar
Send me an email and I will send you a .doc
Old Nov 9, 2006 | 11:26 AM
280Z28's Avatar
Sent
Old Nov 10, 2006 | 05:50 PM
280Z28's Avatar
Still looking for info from an LS2 vehicle.
With the throttle in the closed position:
Rcd = 3.29k, falls as throttle opens
Rce = 1.41k, constant as throttle opens
Rcf = 1.47k, rises as throttle opens
Rde = 2.62k, rises as throttle opens
Rdf = 4.21k, constant as throttle opens
Ref = 2.14k, falls as throttle opens
I did note that Rcd+Rcf=Rde+Ref = 4.76k
Still unsure of how how it works out internally though.
Old Nov 10, 2006 | 07:17 PM
280Z28's Avatar
Well this is the equivalent circuit when the blade is closed. I need a better connector so I can test it as the blade opens.
Old Nov 10, 2006 | 07:22 PM
OldMonte's Avatar
There are three position sensors each of which has a unique slope and voltage, its a redundancy thing
Old Nov 10, 2006 | 07:25 PM
280Z28's Avatar
How are there 3? I was thinking it's:
C: Position sensor 1
E: Position sensor 2
D: +5V ref
F: Gnd
Old Nov 13, 2006 | 05:41 PM
280Z28's Avatar
Wow, post #7 in this thread:
"hrottle Actuator Control, VSS, Scan Tool Normal Ranges 1"
http://www.ls2.com/forums/showthread...hreadid=405808
Old Nov 13, 2006 | 06:14 PM
280Z28's Avatar
My experimentation with the throttle brings me to a conclusion:
I'm controlling the throttle with a simple PID controller for a constant frequency square wave with varying duty cycle. My supply voltage is 5.17V with ~1V drop across my low side driver. The controller sits right around 50% duty cycle to keep the servo open to position A. A reference source (that link 1 post up) states that it should take a 14-26% duty cycle to keep it open to position A.
By my calculation, I've applied an effective (time averaged) 2V source.
2/.26 + 1 = 8.7V
2/.14 + 1 = 15.3V
Is this the correct calculation/conclusion that the servo is built to handle a 9-15V supply? It sure makes perfect sense in an automotive application...
Old Nov 14, 2006 | 03:07 PM
280Z28's Avatar
Got it working on my test bench
Old Nov 14, 2006 | 09:52 PM
280Z28's Avatar
I wrapped this up.
http://www.ls2.com/forums/showthread...hreadid=470902
