View Poll Results: BIG Cube DD
Yes
72
85.71%
No, if so why
12
14.29%
Voters: 84. You may not vote on this poll
BIG cube DD?
Old Nov 18, 2006 | 09:17 PM
MonkeyBoneSS's Avatar
Default BIG cube DD?
Would a big cube motor be a bad idea for a DD? Just want to get a few opinions on the question.
When I say big cube I am thinking 427-461ci.
Old Nov 18, 2006 | 09:54 PM
03 BUSA's Avatar
Not for a DD, I think a 402 setup would be better for a DD. I would think a 402 would have better manners on the street as opposed to a 427 + sized motor.
Old Nov 18, 2006 | 10:19 PM
caindo's Avatar
so you''re saying that the c6 z06 is a bad DD eh? interesting ...
Old Nov 18, 2006 | 10:51 PM
Ellwood's Avatar
Why would it be bad? Little less MPG... make sure it stays cool...
I guess it'd depend on your commute?
I swapped out a 350 and dropped in a 455 in my '68 GTO, neither engine was a screamer, but the extra torque made my commute more enjoyable.
Old Nov 18, 2006 | 11:01 PM
I just want to have something different! Just want to go another route. Don't want another run of the mill H/C LS1 , N2O or a blower, those are all to common nowadays.
Need to break away and try something new in the crowd! Figured the technology is there to support having a big cube as a DD.
Anyone else?
Old Nov 18, 2006 | 11:12 PM
black_knight's Avatar
What? That makes no sense. Manners are caused by the cam/tune of a motor. NOTHING to do with cubes. If anything, a big cube motor would be tamer. Where are you getting your information from?
Old Nov 18, 2006 | 11:16 PM
If anyone has any REAL information on this, I'd like to hear it. Just what kind of MPG does a 427+ motor get as a DD? Besides not running a crazy cam or gears, are there "tricks" to keeping the MPG viable for a DD?
Are there reasons besides that which would make it a bad idea?
Old Nov 19, 2006 | 01:57 AM
Thats what I'm interested in as well!
Old Nov 19, 2006 | 02:48 AM
SLED28's Avatar
I would go with a 447 motor with a 4.125 stroke x 4.155 bore. We have many 4.125 stroke combos out there on the streets and they work great. Lots of power and torque everywhere!
Old Nov 19, 2006 | 03:24 AM
Bring the Noise's Avatar
More Cubes = easier to handle larger lobe cam's not the other way around.
If you have the tune set up correctly a large displacement motor in a car that had an LS1 346 (that is using the same driveline) will only get slightly lower gas mileage then the LS1 did with a proper tune.
Now if you had an LS1 that wasn't tuned and were only get'n 20mpg then the large cube motor with a tune might actually get better gas mileage... Ironic.
Old Nov 19, 2006 | 06:10 AM
LSWaaa?'s Avatar
built SBC ands still be very streetable
Old Nov 19, 2006 | 07:07 AM
I see you're living up to your "got beer" avatar...
Old Nov 19, 2006 | 07:10 AM
LSWaaa?'s Avatar
im just trying to teach people that built SBCs can make BBC numbers without sacrificing driveability.
Old Nov 19, 2006 | 07:11 AM
Also, as I asked in another thread, I'd like to know who, if anyone, is working on keeping the functionality of DOD that the L92 has...
Old Nov 19, 2006 | 03:25 PM
03 BUSA's Avatar
Everyone misunderstood where I was coming from. If you are looking at the LS7 crate motor then I would agree with it being o.k. for a DD. However, most guys who are looking to drop an easy 10k on a 427 or larger cu LSx that I know of are not going with a docile cam type setup, they are looking for 600 + kind of numbers at the wheels and with that in mind, NA this would not be a great DD due to cam specs and compression to hit those numbers. I should have explained where I was coming from a little better. I apoligize. I would prefer to see more guys with 427 NA motors out there, there are too many nitrous, FI and 402's cars running around. I like the idea of doing something different from everyone else.
Old Nov 19, 2006 | 06:14 PM
What would be the projected power output with the 447? (Rear wheel of course)
Old Nov 19, 2006 | 06:27 PM
LOL, too many variables. Heads, cam, intake, exhaust?
Old Nov 19, 2006 | 06:28 PM
11 Bravo's Avatar
To answer the question, no, it would not be a bad idea. Keep the cam around 250 duration or less and it will be more streetable than alot of these h/c 346's running the latest and greatest Godzilla Terminator T-Rex Slayer cams lol. With 100 more rwtq. Go for it.
Old Nov 19, 2006 | 06:33 PM
But of course I do know that. Say with a mild cam nothing to extrem.
What intake could be ran on a 447, LS6 - FAST- LS2?
Also what would be a mild cam for that size motor, 240 or 250?
Old Nov 19, 2006 | 06:41 PM
03 BUSA's Avatar
You would be looking in the range of a carb style or sheetmetal intake for that application. Fast would be the better plastic style intake but depending on other variables would most likely hold some power back.
