Stock LS7 Crank weight
Old Jan 8, 2007 | 09:49 AM
Louis's Avatar
Default Stock LS7 Crank weight
56.05 pounds
Its heavy!
Old Jan 8, 2007 | 11:23 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Do you have any other weights of cranks laying around? Like the stock LS1/LS2, aftermarket cranks, etc? That would be a big help to have the information in one post...
Old Jan 8, 2007 | 12:12 PM
Dragaholic's Avatar
9 Second Club NA
The Callies 4" Dragonslayer weighs about 46 lbs. That should give you an idea if the LS7 is heavy or not.
Old Jan 8, 2007 | 04:03 PM
Louis's Avatar
I have a balanced callies that I shelf ( not sure of the name) and it tips the scales at 49.5.
Ill go ahead and see what cranks I can dig up and weigh them
Old Jan 8, 2007 | 04:05 PM
MeentSS02's Avatar
Thanks Louis!
Old Jan 8, 2007 | 04:57 PM
Mean 69's Avatar
How ironic, with all of the efforts that GM put into reducing weight on the Z06 cars, which is signficant, to have a crank that is this heavy (on top of all things, intertial weight too!!!) is nuts! I mean, ti rods, with a 56 pound crank? That just seem really odd. Of course, the hyper-eut' pistons, and the strange wrist pin designs make you scratch your head too.
Louis, are you working with Callies or anyone else for aftermarket LS7 cranks? I owe you a call, need to find a free minute, but it's looking like I will be building a LS2 based motor after all, L92 heads are in hand.
Mark
Old Jan 8, 2007 | 05:45 PM
See5's Avatar
The LS7 crank is not so stupid when you consider it is a 4" LSx style crank for ~2/3 the price of cheapo Eagle--- (~$750)
Old Jan 8, 2007 | 05:59 PM
Dragaholic's Avatar
9 Second Club NA
Originally Posted by MeentSS02
Thanks Louis!
What...no thanks for me? I had a reputable engine builder weigh mine and that was an actual weight.
Old Jan 8, 2007 | 07:04 PM
aggiez28's Avatar
how much is the ls7 crank?
Old Jan 8, 2007 | 08:59 PM
MeentSS02's Avatar
Well, thank you too then
And to cover my ***, thanks to anyone that weighs their shaft and posts it up
Old Jan 8, 2007 | 09:21 PM
DONAIMIAN's Avatar
I have a stock LS1 crank sitting in the garage at my parents house, but never got a chancethought to throw it on a scale. Anyone know how much weight can be lightened?
Old Jan 8, 2007 | 09:47 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Its common practice for alot of race cars to cut the counterweigths damn near off then add heavymetal near the shaft to allow them to rev faster, if you take weight off you got to add it somewhere else on the crank unless you go with lighter rods and pistons of course.
