Idle video - LS7 with 40 deg. overlap @ .050
I thought this was interesting. Today in the cold weather you can see the cam pulses in the exhaust.
http://www.katechengines.com/street_.../idle_0001.wmv
Originally Posted by Katech
10.92 @ 131.5 on M&H DOT-legal drag radials
SDB
Originally Posted by SDB
10.9 isn't all that great, but 131.5 mph in a full weight F body is haulin!!! That thing should be good for lower 10's I imagine. Do you have the slip from the 1/4 run? Sounds great too.
SDB
SDB
If you put the weight equal (actually 700lbs more) My car should trap 120mph.
Add the difference in power of 140hp (14mph approx) on top of that...... shouldn't that mean a few mph are missing and it should trap mid 130's?!?!
Only explanation I can think of is that the Camaro didn't powershift.
gnx7, why don't you look at lbs per horsepower?
LS7 camaro:
3560 lbs w/ driver. 640 flywheel hp.
3560/640 = 5.56 lbs per hp.
LS1 RX7:
2850 lbs (w/ driver?). approximately 505 flywheel hp.
2850/505 = 5.64 lbs per hp.
both are pretty close in the power to weight ratio. camaro has the slight advantage, so it goes slightly faster.
for what its worth, I put the figures into an ET calculator and got...
rx7, 440rwhp, 2850 lbs = 10.85 @ 125.5
camaro, ~560 rwhp, 3560 lbs = 10.79 @ 126.3
LS7 camaro:
LS1 RX7:
