Livernois Motorsports L92 Heads!
#141
Question - would these ported heads with a matched intake be a better choice than LS7 heads/intake on a NA 427ci-441ci build with a moderately agressive cam and max pump gas compression?
#142
Collections Hold
heads
Originally Posted by john_sblendorio
Question - would these ported heads with a matched intake be a better choice than LS7 heads/intake on a NA 427ci-441ci build with a moderately agressive cam and hight pump gas compression?
#145
Originally Posted by 2c5s
So both engines have stock heads, similar cr and headers. Only major difference is the cam..... you have 13' more intake duration and 13' more exhaust duration and you make less power. Yeah, those L92's suck.
#146
L92 Heads
Did any one notice that GM High Tech compared (as-cast) L92 heads at 70cc
To fully CNC'd stuff at 64cc. The L92 heads will offer even more power if compression was the same. There are flow numbers availabe on L92 heads with intake. Impressive!
#147
#148
A while back I posted this L92 flow comparison:
https://ls1tech.com/forums/generation-iv-external-engine/602115-l76-intake-manifold-flow-results.html
Richard
Richard
#149
Another Flow Data Link
Originally Posted by TA455
I can't find those numbers. Can you, perhaps, provide a link? Thanks.
#151
Originally Posted by red90cobra
is there suppose to be a efi carb version out yet and what does that intake flow?
Take from http://www.gmhightechperformance.com...ine_l92_heads/
That should be the carb manifold you are looking for.
#152
LS1TECH Sponsor
Stage 2 L92 heads IN STOCK and ready to ship!
See post here!
https://ls1tech.com/forums/showthrea...23#post6347123
Thanks,
Chad @ Livernois Motorsports
See post here!
Thanks,
#154
LS1TECH Sponsor
Originally Posted by Chad@LivernoisMotors
The number everyone has been waiting for...
280cc
Thanks,
280cc
Thanks,
This is to clear up some confusion with the intake runner size which I posted in the thread earlier. I want to make it clear based on my post on January 18th that the intake runner size is 280cc. Just so everyone see's the size. I will add it to my first post too.
Thank you.
#155
damn! so many people crying and mud slinging over these heads. hell......most or more then most of the people fighting about them don't even have them ordered yet. well,i do have a set being worked by katech in michigan and like most of the people fighting about them,i hope they do perform because if they don't,i'm the one who will be out of the cash. also,it's the people like me who will have them running on a motor w/dyno and track times that will tell all of you if they are worth it based on dyno and track performance. so,stop fighting,give me and others time to get some results so the rest of you will know what you can expect. you guys have the easy job,just waiting and not spending money on a product that has not yet proven a thing. i'm doing a 402ci w/ported l92 heads,custom cam(i will give specs on it) and l76 intake in a m6 car. the motor should be in and dynoed early april.
be cool guys.
be cool guys.
#156
be cool guys.
be cool guys.
#160
my motor will be in sooner then april. it will be in end of feb-early march,i'm just not dynoing it or taking it to the track till i have atleast 1,000mi on it. the cam will be a custom,but i'm sure it will be a big bitch.
