ETP 215 @ 59cc on a 402 ?
Topend includes:
Vengeance ported Fast/LS2 tb
ETP 215's at 59cc
Would this combo complement the engine or would it choke it off to much? How would my head cc's effect the final SCR/DCR as I "believe" the LS2's have more compression due to the pistons coming further out of the hole?
All replies are greatly appreciated!
Alan
Topend includes:
ETP 215's at 59cc
Alan
SCR of 11.8 on a 402 with 59cc heads and flat top pistons? Maybe if you had a .090 gasket.
You'd need a piston in the -8cc range to get the SCR (and thus the DCR) manageable.
I seem to have a little ring land issue on my LS6 on piston #7, thus the thinking of a bigger cube engine. I'm thinking of a 402 with my current topend and a big cam, or 414 with the L92/L76 combo, or the LS7 bottom end with the L92/L76 combo.....
Regardless of engine I will be going with a big cam, but just wanted some opinion on the 402 with my current heads....
Thanks again!
Small valves and ports on the heads will limit your power.
I have Patriot Performance Stage II 2.055/1.59/59cc heads on a 402 with 14cc dish pistons and a .045 gasket. My compression ratio is 11.17:1.
I purchased the heads and cam for a LS1 and went with them on the 402 just to save money. In the near term I will upgrade to L92 heads and a 240+ duration 600+ lift cam.
Topend includes:
ETP 215's at 59cc
Alan
Worked for me.
Perry
many of the guys on here will tell you..... the heads will hold you back, or you should go with a L92/L76 setup or something like that.
Now while I won't disagree that there are potentially better combo's I will say that the 215's with the fast ported 90 have plenty of airflow to make gobes of power.
Design the cam around the parts you have and you could have a killer combo. No need for a huge duration camshaft. In fact check out this thread.
https://ls1tech.com/forums/generation-iii-internal-engine/649674-line-some-recent-threads-discussing-smaller-cams-milder-combinations.html
Very similar to the top end parts you have. I could see a slightly larger cam maybe a 236/240 or something just a bit larger giving you 600 flywheel HP.
From what Tony show's in this thread and prooves is that the 205/215 size heads are plenty to make awsome power all over the dyno graph.
