L92 DynoJet Numbers Plus Plan B, C, D, E and F...
Old 01-17-2010, 01:39 PM
  #701
MGGLS1's Avatar
Thumbs up
Can't wait to see the results!!
Old 01-17-2010, 02:57 PM
  #702
NA$TY-TA's Avatar
Looking good buddy.
Old 01-17-2010, 05:40 PM
  #703
Shawn @ VA Speed's Avatar
Originally Posted by slowride
How much is to much as far as stroke goes. Can you run a 4.100"-4.125" crank with minimal clearancing? I wish all this stuff was around when I built my 383. I'd assume you can do the same type of sleeve to a l92/ls3 and ls7 block correct?
you have to notch the sleeve,it does protrude below the bottom of the cylinder,but nothing major.yes you can do ls3 or ls7 blocks-just normally is cost prohibitive unless you have one with a bad sleeve already
Old 01-17-2010, 05:41 PM
  #704
Originally Posted by na$ty-ta
looking good buddy.
thanks buddy
Old 01-17-2010, 10:01 PM
  #705
GeorgeInNePa's Avatar
Originally Posted by Shawn @ VA Speed
these can be taken to a 4.155 bore-so if you start at 4.125,you can rebuild several times-this block could last for several seasons even in a race application that gets honed .005 over every season.
How many miles could you expect in a street car with a Darton sleeved 427?
Old 01-18-2010, 08:52 AM
  #706
everything else will be worn out before the block or the sleeves-if you can't go 100,000 miles on a driver-there is something wrong
Old 01-18-2010, 03:24 PM
  #707
WKMCD's Avatar
Sounds like I'll be good for 20 years.
Old 01-18-2010, 08:00 PM
  #708
you can leave anything alone for that long
Old 01-19-2010, 07:17 PM
  #709
WKMCD's Avatar
PM sent
Old 01-20-2010, 01:08 AM
  #710
Richard@WCCH's Avatar
Shawn. This is a really nice presentation of the precision machining required for proper sleeving and block prep. The final result is a solid foundation for a performance build. Thanks for taking the time to show the step by step process.
Kevin is doing a great job keeping pace with the changing demand for larger displacement engines and spotlighting the technological progress of building a potent street machine. His decision to stick with the L92 heads will help demonstrate the true power potential of this mass produced part. It's truly an impressive production design.
Nice work Kevin
Richard
Old 01-20-2010, 12:33 PM
  #711
6.0monsta's Avatar
Shawn at Virgina Speed is an engine building ninja. This is why I had him build my engine! Been extremely happy with my motor.
Old 01-20-2010, 09:11 PM
  #712
Nice work Kevin
Richard
Thanks Richard-can't wait to get those improved heads and see what we can do with them
Old 01-20-2010, 09:18 PM
  #713
Old 01-21-2010, 07:13 AM
  #714
WKMCD's Avatar
I think a lot of people are watching to see how this turns out.
Old 01-21-2010, 07:26 AM
  #715
allngn_c5's Avatar
I think that goes without saying Kevin.
So when you originally had the 403 built, was this already discussed (resleeving the block and making it a 427 down the road) and you were just waiting for the right time to do it?
Old 01-21-2010, 07:31 AM
  #716
WKMCD's Avatar
When I bought the short it was because my 346 had cracked a liner. I had no intention of going bigger. The 403 needed to be freshened and when Shawn and I got to talking...for the cost of doing liners I could make it a 427 and be much stronger in the long run. Nothing sexier than a 427. It's just a classic number.
Old 01-21-2010, 07:43 AM
  #717
allngn_c5's Avatar
Oh ok. You are right about a 427 in a c5 being sexy !!! I might be able to top that, how about Halle Berry in some 5" stillettos, white thigh highes and a thong ? Maybe thats just my idea of sexy, who knows. LOL Maybe Jessica Biel in the same outfit (black) is more your speed, I'd be fine with either one.
Good luck Kevin, between this thread and a couple other ones here on tech there is certainly a lot of anticipation on the upcoming results.
Old 01-21-2010, 07:55 AM
  #718
WKMCD's Avatar
Too many clothes...
Old 01-21-2010, 05:48 PM
  #719
WKMCD's Avatar
The heads are on their way to Richard at WCCH. New CNC program and 2.20 intake valve. I've been running stock L92 vales all this time with no problems but we're going to upgrade the exhaust to stainless also while we're at it.
That is all.
Old 01-22-2010, 09:32 PM
  #720
WKMCD's Avatar
Shawn put up some more pics. All captions are from Shawn at VA Speed.
In the hone with torque plate installed
Here's a picture of the diamond hone stones.These last much longer than the old vitrified stones-they also make a cleaner cut and less tearout.The other benefit is less honing pressure which keeps rounder bores for much better ring seal
Here we are honing.I try to keep the bores within .0001'' of roundness and taper
Here's a screenshot of the readout on the hone.The image to the right is an exaggerated image of the bore,top to bottom
After cleaning the block,here we are in the build room,ready to start measuring and assembly
Quick Reply: L92 DynoJet Numbers Plus Plan B, C, D, E and F...
