L92 DynoJet Numbers Plus Plan B, C, D, E and F...
Old 02-22-2010, 05:29 AM
  #821
WKMCD's Avatar
Originally Posted by sneaks
FAST.......just sayin.
Old 02-22-2010, 05:19 PM
  #822
Shawn @ VA Speed's Avatar
UPDATE:after a few more dyno pulls we did manage to raise the vacuum reading from .7 to 1.0 in. vacuum.and gained a couple hp but nothing to talk about.We are just fighting a losing battle with this intake restriction.Going to sawp out the cam and see what happens-probably nothing great due to the intake,but we have high hopes
Old 02-22-2010, 05:38 PM
  #823
WKMCD's Avatar
Dude, I thought you were better than that.
No problem, I'm sure it will drive out north of 550/520
(On the DJ)
Old 02-22-2010, 10:05 PM
  #824
6.0monsta's Avatar
Shawn,
What would an LS3 427 with a ported Fast92, TFS235s, 1 7/8 headers put out on your dyno?
Build looks fun.
Old 02-22-2010, 11:07 PM
  #825
Richard@WCCH's Avatar
Nice work to this point Shawn. I'm thankful you're taking the time to flog on Kevin's setup. Your findings are similar to what our LS7 customers are seeing. Steady pressure build up in the intake. This situation is very frustrating but with time and R&D can be worked around to a small degree. Kind of like a Cup style restrictor plate engine. Camshaft accordingly.
Kevin, the torque under the curve is going to be really impressive. In due time I'm sure better intake systems will become available. There's a big market for an intake that uses "outside the box" technology. Hang tight. It'll happen. Meanwhile enjoy your "gentleman's cruiser".
Richard
Old 02-23-2010, 04:21 AM
  #826
WKMCD's Avatar
Thanks Richard,
I didn't get to see the heads but Shawn tells me they are a thing of beauty. I expected nothing less coming out of WCCH. I think at the end of the day, I'm going to be extremely happy with this build.
Kevin
Old 02-23-2010, 07:09 AM
  #827
See5's Avatar
In the end you are seeing a "modest" ~6% increase in displacement. To significantly alter the engine's personality it will take a cam change.
Is that what you want?
Old 02-23-2010, 07:23 AM
  #828
WKMCD's Avatar
We're just making a modest cam change.
Old 02-23-2010, 07:48 AM
  #829
hymey's Avatar
See5 remember these heads work better on the bigger bore and especially 427 so the power gains aren't just from displacement. Looking forward to the progress Kevin. Its good to see you posting up preliminary numbers and being realistic about the gains and mods being planned.
cheers
Old 02-23-2010, 08:14 AM
  #830
edcmat-l1's Avatar
At this point, we're thinking the cam may be part of the problem. It may be too small.
Old 02-23-2010, 08:24 AM
  #831
WKMCD's Avatar
cheers
Shawn says he consistently sees about 75hp difference between their engine and chassis dynos. That puts us a 530/515 now. Shawn said a few more pulls on Monday didn't show much improvement. A subtle cam change should net some more and Shawn firmly believes he can make 20-30 more on the engine dyno with the FAST - all of which should make it to the rear wheels. 550/520 on a great driver would be great. As I said, anything over that is a bonus. Nothing being done is at the expense of drivability. That remains the primary priority over peak numbers.
Old 02-23-2010, 09:54 AM
  #832
6.0monsta's Avatar
Did you engine dyno your 402 setup? Just curious for comparisons.
I was thinking it would take 650 to make 550whp? You have an auto or stick...stock gears?
Old 02-23-2010, 10:39 AM
  #833
WKMCD's Avatar
No engine dyno for the 403. All I can go on it what Shawn tells me he sees between the dynos and that's about 75hp on this size build. It will be on the DJ before it's done so we'll all see.
Old 02-23-2010, 10:52 AM
  #834
No engine dyno for the 403. All I can go on it was Shawn tells me he sees between the dynos and that's about 75hp on this size build. It will be on the DJ before it's done so we'll all see.
the 75hp is for a z06 drivetrain.everything else is different.everything affects the rwhp-trans,converter,weight of the clutch,gear ratio,type of rear end etc.
Old 02-23-2010, 11:59 AM
  #835
6.0monsta's Avatar
That explains it. For 550 in a stalled/geared car I'd suspect you need 650 or so. My car seems to have a 17% loss since stock. The math comes out on my 416ci as well. I think the motor was around 600 because it put down 500whp.
Old 02-23-2010, 01:29 PM
  #836
Joe,i would say your numbers are pretty close-i suspect that are goal on yours will be 650-or higher
Old 02-23-2010, 08:14 PM
  #837
UPDATE:new cam in-that is all
Old 02-23-2010, 08:19 PM
  #838
WKMCD's Avatar
Pickup some gas on the way in tomorrow...
Old 02-23-2010, 08:35 PM
  #839
allngn_c5's Avatar
I guess we can expect some more dyno numbers tomorrow afternoon/evening ? Good luck on finding more power without having to sacrifice drivability ...... Thats should be everyones goal that doesn't track there car. Stock like drivability, but can get wild with a stab of the accelerator !! Good luck Kevin !!
Old 02-23-2010, 09:07 PM
  #840
veee8's Avatar
And your camera. , you know why Shawn.........
Awesome buildup Kevin!!! I love the methodical approach you have always taken in this thread.
Quick Reply: L92 DynoJet Numbers Plus Plan B, C, D, E and F...
