L92 DynoJet Numbers Plus Plan B, C, D, E and F...
Old 02-28-2010, 01:11 AM
  #901
hymey's Avatar
Originally Posted by WKMCD
500 RPM idle.....
1.5hp per cube and stock idle speeds..not bad I say
Old 02-28-2010, 07:22 AM
  #902
WKMCD's Avatar
Originally Posted by crakhead
Nice numbers Kevin.....I wish when i was stationed at Newport News, VA SPEED were around.....I would be all over them.
It's because of you guys that keep me going in the quest for HP out of the L92 Heads....
I sort of look at this like the old hot rod days when aftermarket heads and other parts weren't available. People had to learn how to make the factory stuff work.
Old 02-28-2010, 08:09 AM
  #903
66deuce's Avatar
and what's cool today is you can get big power with a smooth idle and good drivability,unlike the "good ole days"..
Old 02-28-2010, 06:39 PM
  #904
WKMCD's Avatar
The man his self
Old 02-28-2010, 06:59 PM
  #905
Shawn @ VA Speed's Avatar
The man his self
sure doesn't look like much
Old 02-28-2010, 07:01 PM
  #906
69LT1Bird's Avatar
...and this thread was making such good progress
Old 02-28-2010, 07:08 PM
  #907
WKMCD's Avatar
His head is MUCH bigger in person.
Old 02-28-2010, 07:38 PM
  #908
8ByGoat's Avatar
Originally Posted by 69LT1Bird
The FAST actually working on Kevin's new engine isn't a surprise. The LS7 FAST worked on the LS7. Apparently the LS3 style FAST intakes like big cubes too.
If it is going to work it will be on his car.
If I have read everything right the FAST was worth 14/15 on an engine dyno vs the ported LS3 right?
Old 02-28-2010, 08:00 PM
  #909
WKMCD's Avatar
Correct. The FAST was only port matched. The real work on it happens this week.
Old 03-01-2010, 08:23 AM
  #910
Stang's Bane's Avatar
That's just stupid knowing the size of the cam. So 575RW and infinitely drivable.
Impossible, bigger cams are better
Great job guys!!!
Old 03-01-2010, 05:54 PM
  #911
WKMCD's Avatar
Old 03-01-2010, 06:31 PM
  #912
69LT1Bird's Avatar
Ya, what the heck, where are the stinking updates?
Old 03-01-2010, 07:22 PM
  #913
wish i only had one project to worry about
Old 03-01-2010, 08:01 PM
  #914
thedak's Avatar
I want to see how much this TB is honestly worth on a stroker.
I am on the fence about buying a NW 102mm DBW or an ERL 102 DBW TB.
Old 03-01-2010, 08:03 PM
  #915
we're not using a 102
Old 03-02-2010, 05:28 AM
  #916
WKMCD's Avatar
Must be a 102.3mm. Good for .03% more power.
Old 03-02-2010, 06:47 AM
  #917
allngn_c5's Avatar
What are you guys using? Not going to send Kevin home with 90 mm tb? Do I smell 105/105 ? (That is if the inlet can be opened to 105)
Old 03-02-2010, 09:40 AM
  #918
formula17's Avatar
I had thought about doing a 105, But was waiting for someone else to try it first. Interested to see that, IF that's what you guys did.
Old 03-02-2010, 09:51 AM
  #919
WKMCD's Avatar
I don't see much sense going bigger than the manifold - but who knows.
Old 03-02-2010, 10:27 AM
  #920
69LT1Bird's Avatar
Then you could be really old school, put a velocity stack on it.
Like dual quads on a 350 sbc.
Quick Reply: L92 DynoJet Numbers Plus Plan B, C, D, E and F...
