Whose making 550rwhp N/A on a 402 LS2 stroker
Not sure what you have planned for a fuel, but if it's a race gas, you aren't gonna be driving that every day unless you like spendign 500 a week on gas, just to go back and forth to work. My 402 with the th400 and 4.10's will go thru 50 bucks of 104 unleaded in one round trip to work (26 miles one way) and I get the 104 for about 6.50 a gallon... so do the math.
We also just had a 402 w/ AFR 225's just tip the scale at 544rwhp with a 242/250 cam. Cost just under $9000.
Both are under 11.5:1 compression.
There is a website with more info, run e85 dot com. What he has is do-able but may limit him to e85, if that's his juice of choice.
I made 466 rwhp unlocked through a th350, 12 bolt, 4:10's and slicks on 104 octane.
The car weighs 3350 with me in it and I've run a best of 10.25@129. I've also hit a best short time of 1.32 and have been running consistently in the lower 1.3's.
I drive this on the street regularly and have not had the valve covers off in 2 years.
I love this motor
Whose opinion matters?
I decided to take a pass on the motor I referenced here after many long hours of soul searching, b/c the compression (primarily dynamic) is too high for my own peace of mind for a street motor (that will only see limitied track use).
I am now talking with LME and Canadian Perf. about building me a Trick FLow headed 416 L92 motor and even possibly a 430 CID Trick Flow headed LS7 motor (the engine i really want but exceeds what i want to spend). Either motor would have 11:7 to 1 compression with a dynamic compression of 8:6 to 1, and should make 550rwhp in my C5 Z06 with pump gas, a ported fast 90 and a nice cam in the range of a 244/250, on a 112 lsa!
If i don't pull the trigger will just keep my current blown LS6 motor for another year and this time next year build a 600rwhp, 482 CID LSX motor!
