Whose making 550rwhp N/A on a 402 LS2 stroker
NOTHING, but that old N/A bug is biting me after 2 seasons and I want to do more road racing where N/A is the desired choice in a motor!
and i think thats gonna be best case scinario
I found a tuner who has has built one at 12:1 to 1 compression (9.1 to 1 dynamic compression), TFLow 225s, and running a BABY cam 236/240 cam, who is running N/A 10.3s in his 3400 lb F-Body, at 136, through a MANUAL TRANNY, and 4.57 gears and making 551rwhp and 495rwtq through a 9 inch rear end, big slicks, SAE correct on a dyno jet and i have seen his video and time slips that back up the dyno numbers. I don't know, but seems as if a few are doing it (and he tested 6 different cams) some much larger and the baby cam is making the most power. This is running on 100 unleaded at the track though and that certainly does make a difference and the higher compression seems to be the difference here along with the best heads on the market the TFS 225 (out of the box)!
Also has a fast 90 which is ported and good for 15rwhp according to his dyno tests. Some motors just have the right COMBO and make HUGE POWER and this seems like one of them.
Im Not Saying You Cant Run Big Cams As Im Runnin A 237/242 On A 113 And My Car Is Very Streetable.. And I Made 430 Rwhp Through A Unlocked 4000 Stall But To Say That A Slightly Bigger Cam And 50 Cubes Would Net Me Another 120 Hp Seems A Little Optimistic (but Not Impossible I Guess)
Already have the motor built and ready to buy and it runs consistent 10.3s at 134 to 136 mph (all motor) on a 3400 lb race weight Z28, with a MAUAL TRANNY. Big stalled auto would run into the 9s with that type of power this is making. Has less than 100 miles on a brand new motor and 20 dragstrip passes (no spray/N/A). The track is what matter and we know this and this particular 12:1 to 1 compression 225 Trick Flowed Headed LS2 402 is certainly hauling the mail and should propel my Z06 into mid 10s all day and that's what i'm looking for!
Was just wondering who else is having these type of result on a max effort 402!
You can't go wrong with w2w. They build some of the best lsx motors out there. They get you exactly what you want.
