L92 valve to bore clearance
Old Jun 10, 2007 | 11:24 AM
LSPerformance's Avatar
Default L92 valve to bore clearance
Has anyone measured valve to bore clearance on the L92 setup? - if so, what bore size did you measure on?
Old Jun 10, 2007 | 11:38 PM
Richard@WCCH's Avatar
The L92's nominal bore size is 4.00". Exactly what measurement are you searching for?
Richard
Old Jun 10, 2007 | 11:39 PM
Wnts2Go10O's Avatar
Richard
i think hes thinking from the edge of the valve to the cylinder wall. dunno
Old Jun 11, 2007 | 07:22 AM
Yes, valve "edge" to bore clearance @ 4.000" bore - I thought the nominal bore size for the L92 was 4.065"?
Old Jun 11, 2007 | 09:40 AM
The valves aspect to the bore changes as it moves off the seat. The valves move toward the center of the cylinder and away from the bore edge as they leave the seat. Nearest I can tell the closest point of valve/bore distance is as follows:
The stock intake valve (2.160") leaves approx. .153" from the closest valve edge to the bore. The exhaust valve has a distance of .047" from valve edge to bore.
Hope this helps.
Richard
Old Jun 11, 2007 | 10:16 AM
Hope this helps.
Richard
Richard, is this with the 1.590" exhaust? - and both measurements are on what size bore?
Thanks
Old Jun 11, 2007 | 06:04 PM
Thanks
Stock L92 valve diameters and 4.00" bore.
Richard
Old Jun 11, 2007 | 08:56 PM
Thanks!
Old Jun 11, 2007 | 09:23 PM
the_merv's Avatar
That's a tight clearance on that Exhaust..
