Looking to build a motor...
basically what would you guys do?...i kinda want to have a project of my own building it from scratch...as of now i have 4K to spend...but i put up about $300 a week for mod money...also my plans for the car will be pretty much 50/50 street/strip...it'll see street time but ALOT of strip as well...it'll have alot of weight saving mods...
As far a cheaper options for big cube motors checkout our 408 iron & 402 aluminum engines. They're currently on HUGE special & we stock approx 30-40 engines! The last thing you want to do is buy a $4000 product from someone and wait several months for it to be built.
http://www.texas-speed.com/shop/cate...MID=3&catid=28
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
http://www.schwankeshortblocks.com/Short%20Blocks.htm
We can top it off however you would like.
good advice man and thanx....as far as the roller goes...i havent really set a budget...the project budget will be 10-12K im expecting that...i just dont wanna pay that OR more for a fbody with a stock LS1 in it and tear it down and put 5K PLUS back into it...cause then id be spending money i wouldn't have from a ground up build...but ill defently keep that in mind and keep my eyes open for a good roller around here on tech...
As for another question for you guys...whats the diff between a truck 6.0 iron block and a LS2....they are the same cubes correct...which is better?Or is it just the iron/alum thing the only real diff?
